vidoardes
Connection drops out same time every night, lots of errors
I have seen this issue a few times on the forum, but never a solution that could be implemented by myself. Every night, without fail, between 12pm and 1am our internet drops out. The connection quality seems poor during the day, and the home page of the hub says Partial Service (DS Only).
Looking at the logs there are also a lot of errors, RCS Partial Service and Lost MDD timeout. I have tried pin resetting and running a test from the website which did show and error and claimed it was sending a fix, but after a second test and "the all clear" I am still seeing the errors. Details are below:
1203000000-2.237256 qam9
2211000000-2.437256 qam10
3219000000-1.724256 qam11
4235000000-1.937256 qam13
5243000000-2.437256 qam14
6251000000-1.937256 qam15
7259000000-1.237256 qam16
8267000000-1.737256 qam17
9275000000-2.237256 qam18
10283000000-237256 qam19
11291000000-1.737256 qam20
12299000000-0.737256 qam21
13307000000-1.537256 qam22
14315000000-1.437256 qam23
15323000000-0.737256 qam24
16331000000-137256 qam25
17339000000-0.737256 qam26
18347000000-0.237256 qam27
19355000000-137256 qam28
20363000000-137256 qam29
21371000000-0.238256 qam30
22379000000037256 qam31
233870000000.238256 qam32
1Locked37.6800
2Locked37.6310
3Locked24.251144226903270
4Locked37.6430
5Locked37.3350
6Locked37.3290
7Locked37.3270
8Locked37.3370
9Locked37.3170
10Locked37.3880
11Locked37.390
12Locked37.3160
13Locked37.380
14Locked37.3300
15Locked37.3430
16Locked37.6170
17Locked37.6130
18Locked37.660
19Locked37.630
20Locked37.6130
21Locked38.6100
22Locked37.670
23Locked38.680
14620000051512064 qam3
26030000051512064 qam1
35370000051512064 qam2
43940000051512064 qam4
1ATDMA0010
3ATDMA0000
4ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt057-b.cm
SFID113230
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID113229
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Connection drops out same time every night, lots of errors
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
The Signal Noise Ratio (SNR) on Downstream Channel 3 is far too low, this will account for the High Pre & Post RS Errors.
Your Upstream Power Levels are maxed out.
This will need an engineer to put right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 10 days average) until one of the VM Forum Staff comes along.
1Locked37.6800
2Locked37.6310
4Locked37.6430
vidoardes
