rcrummack
  • 10
Message 1 of 22
Confused over speed tests
Hi, looking for some advice please!
Current set-up is Hub 3 in living room, couple of bits wired to it, but then also an ethernet cable which goes to a network switch and then out to the garage/office area.
We have a Nova5 mesh system running as well with 3 units.
However, regardless of switches or direct cable to the Hub, the maximum speed I seem to get on my two laptops is approx 92 download and 42 upload.
This is the same whether I am wired directly into the hub with my laptop, or in the garage wired in from after switches.  The switch is gigabit.
I've used "speedtest" for checking and it shows the 92/42 result.  I've also used the Virgin "SamKnows RealSpeed" test which gave me a suprise result (to me anyway).  Speed to hub is around 640-650Mbps Download (great as I pay for 600Mbps; but the speed to computer matches the 92Mbps result.  Again, I've checked this direct cable to hub and also in garage.
Why is there such a variance from the 640-650 into the house, to the below-100Mbps being used or offered to my hardware?  Both laptops are giving same result, work one is much newer and faster processor than my personal laptop.  Not an expert on processors but I assume that i7 for work should be better than my personal i3 machine?
Cables are all Cat5e or 6; would need to check each one to be 100% on what is where in the network.
Any ideas how I can improve the results seen to my devices please?
Eeeps
  • 818
  • 53
  • 136
Well-informed
Message 2 of 22
Re: Confused over speed tests
Does sound like the Ethernet is only running at 100Mb/s
If the laptops are Windows 10 do the following...
In the search box type 'ethernet settings'
You should see your ethernet connection. Click this and look at the properties at the bottom of the page.
It should show 1000/1000
  • 16.28K
  • 711
  • 1.6K
Message 3 of 22
Some laptops have 100Mb NIC
rcrummack
  • 10
Message 4 of 22
Thanks, sadly I cannot see the 1000/1000 line.
I've gone to settings, ethernet section, then clicked on my wired connection name.
Shows network profile
Metered connection
IP settings
Properties  (Is this the right page to be looking on)
Under properties I've got various IP addresses, and bits on driver, but no indication of speed capacity.
Same on both laptops.  Am I just looking in the wrong place?  Thanks again
  • 16.28K
  • 711
  • 1.6K
Message 5 of 22
In the search box put in "Network Connections" then double click on your ethernet
conman33158
  • 1.55K
  • 131
  • 295
Super solver
Message 6 of 22
Type in "View network connections" in your search bar bottom left, then right click your Ethernet connection and select "Status" What does it say for speed? Should read 1Gbps or better?
rcrummack
  • 10
Message 7 of 22
Thanks for that step-by-step!
Both laptops show 1Gbps under status.
  • 16.28K
  • 711
  • 1.6K
Message 8 of 22
Have you tried connecting the laptops to the hub without a switch?
rcrummack
  • 10
Message 9 of 22
Yes, unplugged everything else and just had laptops wired to the Hub on a 0.5m Cat6 cable.  Both laptops, same results.
If I was getting 3-400 Mbps still, I'd be happy, but can't understand why the drop off from 650 to 90.
sophist
  • 2.55K
  • 420
  • 683
Message 10 of 22
it's probably the connection between the switch and the hub that's negotiating at 100mb - not sure if the hub shows this, or if you can find out from the LEDs on the switch, or if it's a managed switch, log into it and see what speed the port is at..
