DJ_Shadow1966
  • 7.28K
  • 1.38K
  • 2.11K
Message 1 of 17
Check stats as speed only getting around 25mbs
Hello Teamies
Can somebody have a quick look at stats as I am only getting 25mbs.
Cable Modem StatusItem Status CommentsChannel Overview Downstream Upstream
Cable Modem Status
Online
DOCSIS 3.1
Primary downstream channel
Locked
SC-QAM
DOCSIS 3.0 channels
31
4
DOCSIS 3.1 channels
0
0
3.0 Downstream channels
25331000000-4.738.6QAM25625
1139000000-4.629.8QAM2561
2147000000-6.429.6QAM2562
3155000000-4.629.6QAM2563
4163000000-4.630.4QAM2564
5171000000-2.830.2QAM2565
6179000000-5.130.2QAM2566
7187000000-3.433QAM2567
8195000000-2.535.1QAM2568
9203000000-531.7QAM2569
10211000000-4.735.6QAM25610
0219000000-416.5UNSUPPORTED0
0227000000-4.514.7UNSUPPORTED0
13235000000-4.336.6QAM25613
14243000000-5.536.4QAM25614
15251000000-5.434.3QAM25615
16259000000-5.937.4QAM25616
17267000000-6.236.6QAM25617
18275000000-637.6QAM25618
19283000000-6.337.6QAM25619
20291000000-4.638.6QAM25620
21299000000-6.636.4QAM25621
22307000000-3.937.6QAM25622
23315000000-4.738.6QAM25623
24323000000-4.937.4QAM25624
26339000000-4.637.4QAM25626
27347000000-3.737.4QAM25627
28355000000-5.936.4QAM25628
29363000000-3.937.4QAM25629
30371000000-7.737.4QAM25630
31379000000-537.4QAM25631
25Locked38.60537700
1Locked29.806774599577199652
2Locked29.57447677220723135
3Locked29.61995312219611791
4Locked30.42091872005150
5Locked30.2064082870082203
6Locked30.2064081878190
7Locked32.962662209030
8Locked35.0835491456750
9Locked31.6886695059400
10Locked35.5950783389260
0NotLocked16.48347504238
0NotLocked14.71076202491
13Locked36.6096532980
14Locked36.3868903950
15Locked34.3456882620
16Locked37.35598800
17Locked36.60965300
18Locked37.63627600
19Locked37.63627600
20Locked38.60537700
21Locked36.38689000
22Locked37.63627600
23Locked38.60537700
24Locked37.35598800
26Locked37.35598800
27Locked37.35598800
28Locked36.386890270
29Locked37.35598800
30Locked37.35598800
31Locked37.35598800
1st page
DJ_Shadow1966
  • 7.28K
  • 1.38K
  • 2.11K
Message 2 of 17
Re: Check stats as speed only getting around 25mbs
2nd Page
3.0 Upstream channels
160300000535120 KSym/sec64QAM9
23940000053.85120 KSym/sec64QAM12
34620000050.85120 KSym/sec64QAM11
45370000053.35120 KSym/sec64QAM10
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
wrkldJKDHSUBsgvca69834ncx
SFID
20832
Max Traffic Rate
402500089
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
20831
Max Traffic Rate
38500089
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
bestEffort
Regards Mike
gitty
  • 257
  • 67
Superfast
Message 3 of 17
That doesn't really look good. Have you checked for bad cables and bad/loose connectors?
  • 15.84K
  • 2.1K
  • 4.97K
Message 4 of 17
Jeepers Mike,
You have two downstream channels (11 and 12 ) that aren't being picked up.
Your upstream channels are over the maximum value (should be lower than 51, preferably a lot lower)
There should be very few if any pre post errors with it being a new connection.
As per gitty I would check for loose cables/connectors, especially the white coaxial, also check the external omnibox..
Have you tried a one minute factory reset (or do it via the hub interface > Admin > Reload & Reboot > Restore to factory defaults)
Dave
Love, love and love, forever - Pele
DJ_Shadow1966
  • 7.28K
  • 1.38K
  • 2.11K
Message 5 of 17
Hello
Yep I have checked all connections both internal and external, and gone the full length of the internal cable and no damage too cable. Everything is nice and tight, no damage.
Regards Mike
DJ_Shadow1966
  • 7.28K
  • 1.38K
  • 2.11K
Message 6 of 17
Hello
Also just done a full reset using the admin interface and no change.
Regards Mike
gitty
  • 257
  • 67
Superfast
Message 7 of 17
Okay, so now you are waiting for the staff. They might be able to see, if your neighbours are also affected. 🙂
  • 6.79K
  • 591
  • 1.78K
Message 8 of 17
@DJ_Shadow1966 wrote:
Hello
Regards Mike
Try checking with Area faults on 0800 561 0061 or if you have a VM landline 150 as small local faults are not listed on the VM status page.
But your power levels are shocking, all over the place.
DJ_Shadow1966
  • 7.28K
  • 1.38K
  • 2.11K
Message 9 of 17
Hello
Yeah checked for local issues on 0800 and there is not anything recorded in the area. Yeah I looked at my stats myself and they didn't look good to me either.
Regards Mike
  • 13.87K
  • 1.07K
  • 2.81K
Message 10 of 17
Hi Mike
On thing I can think of is that as the connection was unused for sometime that a technician has moved the (then unused) cable to a different tap on the street cabinet. Are you a long way from the cabinet? I am and your stats look like mine did when I was moved to a different tap in error. Every time I see a VM van in my road I keep my fingers crossed!
