  • 7
Message 1 of 13
Changed from m200 to m350 package but not getting faster speed
I recently changed my internet package from m200 to m350 and I don't seem to have seen any increase in speed, could you please investigate this for me, the speed results I have obtained from www.speedtest.net just now was: -
214.13 download
21.16 upload
8ms ping
I use my Super Hub 3 in modem mode connected via ethernet cable and the test was performed wired. Data from the hub as requested: -
1 322750000 2.5 38 256 qam 24
2 186750000 3.7 38 256 qam 7
3 194750000 3.5 38 256 qam 8
4 202750000 3.2 38 256 qam 9
5 210750000 3 38 256 qam 10
6 218750000 2.7 38 256 qam 11
7 226750000 2.5 38 256 qam 12
8 234750000 2 38 256 qam 13
9 242750000 2 38 256 qam 14
10 250750000 2 38 256 qam 15
11 258750000 2 38 256 qam 16
12 266750000 2.2 38 256 qam 17
13 274750000 2 38 256 qam 18
14 282750000 2.2 38 256 qam 19
15 290750000 2.2 38 256 qam 20
16 298750000 2.2 38 256 qam 21
17 306750000 2.2 38 256 qam 22
18 314750000 2.5 38 256 qam 23
19 402750000 2.5 38 256 qam 25
20 410750000 2.7 38 256 qam 26
21 418750000 2.5 38 256 qam 27
22 426750000 2.5 38 256 qam 28
23 434750000 2.5 38 256 qam 29
24 442750000 2.2 38 256 qam 30
1 Locked 38.6 3313 219
2 Locked 38.6 80769 1669
3 Locked 38.9 62107 1366
4 Locked 38.6 49983 1109
5 Locked 38.6 39034 915
6 Locked 38.9 30926 908
7 Locked 38.9 26199 664
8 Locked 38.6 21825 565
9 Locked 38.9 17725 406
10 Locked 38.6 14454 327
11 Locked 38.6 11939 268
12 Locked 38.6 9493 227
13 Locked 38.6 8074 213
14 Locked 38.6 6978 225
15 Locked 38.6 6019 201
16 Locked 38.6 5246 228
17 Locked 38.9 4524 178
18 Locked 38.6 3806 207
19 Locked 38.9 1924 260
20 Locked 38.6 1894 177
21 Locked 38.9 1727 226
22 Locked 38.6 1579 206
23 Locked 38.9 1856 134
24 Locked 38.9 1662 271
1 39400000 4.95 5120 64 qam 4
2 46200000 4.9 5120 64 qam 3
3 53700000 4.875 5120 64 qam 2
4 32600000 4.9 5120 64 qam 5
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
06/06/2020 19:04:10 notice LAN login Success;CM-MAC=xx:xx:xx:xx:xx:cb;CMTS-MAC=xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
06/06/2020 19:03:23 Warning! RCS Partial Service;CM-MAC=xx:xx:xx:xx:xx:cb;CMTS-MAC=xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
06/06/2020 19:00:39 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=xx:xx:xx:xx:xx:cb;CMTS-MAC=xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
04/06/2020 20:24:55 critical No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:cb;CMTS-MAC=xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
04/06/2020 18:21:28 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=xx:xx:xx:xx:xx:cb;CMTS-MAC=xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
03/06/2020 10:51:24 Error DHCP RENEW sent - No response for IPv4;CM-MAC=xx:xx:xx:xx:xx:cb;CMTS-MAC=xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
29/05/2020 01:10:33 critical No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:cb;CMTS-MAC=xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
27/05/2020 12:41:44 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=xx:xx:xx:xx:xx:cb;CMTS-MAC=xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
26/05/2020 14:43:33 Error DHCP RENEW sent - No response for IPv4;CM-MAC=xx:xx:xx:xx:xx:cb;CMTS-MAC=xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
25/05/2020 11:55:27 critical No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:cb;CMTS-MAC=xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
23/05/2020 06:10:28 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=xx:xx:xx:xx:xx:cb;CMTS-MAC=xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
22/05/2020 01:16:49 Error DHCP RENEW sent - No response for IPv4;CM-MAC=xx:xx:xx:xx:xx:cb;CMTS-MAC=xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
17/05/2020 20:28:59 critical No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:cb;CMTS-MAC=xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
17/05/2020 15:20:26 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=xx:xx:xx:xx:xx:cb;CMTS-MAC=xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
16/05/2020 18:21:36 Error DHCP RENEW sent - No response for IPv4;CM-MAC=xx:xx:xx:xx:xx:cb;CMTS-MAC=xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
13/05/2020 13:26:9 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=xx:xx:xx:xx:xx:cb;CMTS-MAC=xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
13/05/2020 12:29:48 Error DHCP RENEW sent - No response for IPv4;CM-MAC=xx:xx:xx:xx:xx:cb;CMTS-MAC=xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
13/05/2020 12:09:48 critical No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:cb;CMTS-MAC=xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
12/05/2020 07:24:42 Error DHCP RENEW sent - No response for IPv4;CM-MAC=xx:xx:xx:xx:xx:cb;CMTS-MAC=xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
09/05/2020 10:12:43 critical No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:cb;CMTS-MAC=xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
Cable Modem Status
Item Status Comments
Acquired Downstream Channel (Hz) 322750000 Locked
Ranged Upstream Channel (Hz) 39400000 Locked
Provisioning State Online
  • 20.96K
  • 1.14K
  • 2.7K
Message 2 of 13
Re: Changed from m200 to m350 package but not getting faster speed
How recent is recent?
  • 7
Message 3 of 13
The change was requested on 29th May and in the my account page it says I have the m350 package now as below:-
Broadband
Our broadband doesn't get quicker than this.
You're on our top speed broadband tier!
M350 Fibre Broadband
  • 20.96K
  • 1.14K
  • 2.7K
Message 4 of 13
Have you tried rebooting the router?
A last resort as well would be trying a factory reset on it, but as you are in Modem Mode the repercussions aren’t as bad
  • 7
Message 5 of 13
I have powered off and on the router since the upgrade should have taken place.
Does a factory reset normally fix these types of issues. Do the figures in my first post look like I should be getting the m350 speeds?
  • 20.96K
  • 1.14K
  • 2.7K
Message 6 of 13
You need to post what’s on the configuration tab
  • 7
Message 7 of 13
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-rtsxl20016u-b.cm
SFID 482556
Max Traffic Rate 230000061
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 482555
Max Traffic Rate 22000061
Min Traffic Rate 0
Max Concatenated Burst 42600
Scheduling Type BestEffort
  • 2.87K
  • 51
  • 263
Problem sorter
Message 8 of 13
That Config is still the 200Mb/s one.
A factory reset can get you a Firmware Update if its in your area but not on your HUB yet but a Config file is downloaded every time you reboot the HUB so I would not do so unless you do not have many settings to redo.
I would say VM have not updated your account yet.
  • 7
Message 9 of 13
I am trying a factory reset now and will repost the configuration data when it is back up. Thanks for the replies.
  • 7
Message 10 of 13
I have just factory reset and put back into modem mode and below is the configuration data. Is this still m200 settings if so how do I get Virgin to update it to the m350 settings?
Network access
Allowed
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
SFID 484786
Min Traffic Rate 0
SFID 484785
Min Traffic Rate 0
