Atomichobo
  • 44
Dialled in
Message 1 of 21
Change package to VOLT but not had broadband speed increase?
Recently negotiated an upgrade to VOLT with an o2 SIM card and virgin BB.
I removed my landline as part of the package deal.
I have received the O2 sim, but not had my broadband speed boost. Any suggestions?
Do I have to wait for the existing contract to end?
Tags (2)
  • 6.81K
  • 592
  • 1.78K
Message 2 of 21
Re: Change package to VOLT but not had broadband speed increase?
The VM VOLT part of the upgrade takes 14 days to implement.  Also make sure the O2 and VM accounts are EXCATLY the same, names, addresses etc. or the upgrade may fail.
Atomichobo
  • 44
Dialled in
Message 3 of 21
ok thanks.
They guy who sorted it out seemed to know what he was doing and suggested the speed boost would be available straight away.
I'm happy to wait a bit and see what happens.
Tags (3)
Zach_R
  • 4.9K
  • 159
  • 337
Message 4 of 21
Hi @Atomichobo,
Thank you for your posts and welcome back to our community forums. We're here to help.
Apologies for any confusion with the Volt package and benefits. The benefits are applied within 14 days after the Volt package begins or you've opted in to receive the benefits, assuming you're eligible. It's possible that you'll receive the O2 benefits before the Virgin Media benefits or vice versa, but they will both be applied within 14 days.
If the 14 days have passed and they're still yet to be applied for you, please let us know and we can go from there.
Zach - Forum Team
Atomichobo
  • 44
Dialled in
Message 5 of 21
It's now been 3 weeks and I have got my O2 benefits, but no changes to the VM account.
Chris_W1
  • 6.57K
  • 275
  • 440
Message 6 of 21
Hi Atomichobo, thanks for the message. The Virgin Media change would come 14 days after it has been added, can you confirm when the volt change was done and what speed you are getting over the speed test? ^Chris
Atomichobo
  • 44
Dialled in
Message 7 of 21
Is that 14 days from the contract changeover as that only happened a few days ago?
currently on 350-370down 36up.
i do however already have the double data on my o2 sim.
Roger_Gooner
  • 8.75K
  • 558
  • 1.66K
Message 8 of 21
I got a package change which involved moving my Virgin Mobile to O2 and a broadband upgrade from M350 to M500. Once the account change goes through and the new configuration file is sent to your hub you get the speed increase with no need to reboot it. I got M500 soon after getting off the phone.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG108S 8-port gigabit switch, V6
My Broadband Ping - Roger's VM broadband connection
Atomichobo
  • 44
Dialled in
Message 9 of 21
As I have 36mbps upload, does that suggest I have received the boost, but the limit in my area is 360/370mbps?
Roger_Gooner
  • 8.75K
  • 558
  • 1.66K
Message 10 of 21
If you have 360/370Mbps then you're on M350. Your speeds are limited by the hub's configuration file not the area you're in (unless there is congestion or a fault). When you get your upgrade to M500 your config should look like this.
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt053-b.cm
SFID191672
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID191671
Max Traffic Rate38520000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
