Troj
CONSTANT Connection issues August 2020
I’m getting intermittent connection issues constantly. It drops out every 10 mins or so. I’ve called up VM countless times but everything appears fine. Even got a new router, yet it keeps happening. Tried all the connections and resets i can do. Even took all the devices off and just used 1 device via ethernet ... and it still happens. Can’t seem to do anything with this internet, and yet i keep being told everything is fine. It has worked fine all year so far, only the last 2 weeks i’ve experienced these issues.
Any idea what is going on? I’ve not been able to search all the community questions since the internet keeps cutting out and takes soooo long to get back to this stage. So forgive me if this has been asked already.
thanks!
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: CONSTANT Connection issues August 2020
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
dinth
  • 47
  • 45
Dialled in
Hey. Are there any new apps/services you are using since this issue showed up? Like torrents or VPN clients?
