Broadband
steveanniss1
I currently pay for 500Mb broadband and an receiving less than 70Mb. The VM line test reports there are no issues.
1 ACCEPTED SOLUTION
Accepted Solutions
Your device may be using the "intelligent wifi" feature and be connecting on the 2.4GHz wifi band as the signal is "stronger" - but which will always be that slow - rather than the faster 5GHz one.
Separate the 2 frequency SSID's in the Hub settings and than connect to them individually and do a speed test
4 REPLIES 4
Is that over wifi or an ethernet cable connection?
If wifi test it on a Cat5e/6a ethernat cable. If on ethernet - swap the cable for a new Cat6a one.
Also, what make/model of device are you testing it on ?
Admittedly, I'm on WIFI but ordinarily my speed via this source is around 530 Mb.
Keezza
Yeah band steering always sucks. I can't get around it at work, really.annoying. Band steering isn\t even part of the 802.11x spec haha!
