scoobymark1
Broadband
My speed had been very low for a good month now and it's getting worse, I've been doing speed tests and the lowest I've seen is 0.5 mbps
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Broadband
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Broadband
Please post a 'Live Link' to your BQM on here.
Tags (1)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Broadband
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Tags (1)
