Steve333
Broadband
I used to get 200mb download and now for the last 2 months since renewing my contract I only get around 20. I’ve been with you guys for years now and I know what to do about resetting, turning it off and on etc. I’ve tried to phone but kept on hold for hours and still not being able to get through. This is my last hope. Please help.
Anonymous
Not applicable
Re: Broadband
are you using wireless to test?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Broadband
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
 then
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
