Ulsterknight
Broadband
Our broadband is supposed to be 200mbs download currently speedy test shows less than 2mbs.  This has been an issue off and on for a number of months now.  When you go to check if there is issues in the area; the page doesn’t load. It is actually got worse since I updated the package from 100 to 200..
Im tired that excuses are used  that the pandemic Is effecting support.  Any business adapts to deliver a service, but not 8 months down the line.
If Virgin can’t deliver promised speed; have I a right to terminate within the contracted period to get another provider?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Broadband
Then
Can you please
