dhackett136
  • 21
Message 1 of 38
Broadband
I have broadband Fibre 350 however the speeds keep dropping to around 1mbs to 100mbs this has been happening for three weeks.  I have had a new hub.  Wi-Fi boosters and reset the hub loads this is still not working.  I stream but haven’t been able to due to the connection
Tags (3)
dhackett136
  • 21
Message 2 of 38
Re: Broadband
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 38
Re: Broadband
What is your connection like using  a direct connection with a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other items connected ?
dhackett136
  • 21
Message 4 of 38
Re: Broadband
The same.  The internet connection continually goes up and down
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 38
Re: Broadband
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click Post again.
Can you set up a Broadband Quality Monitor (BQM) at thinkbroadband.com - this will give you an insight into what is happening with the signal at the other side of the Hub, it will take a few hours to get any kind of trend showing although you can post the link straight away.
 In the URL box paste the link you copied and then click OK - you can post the link straight away.
dhackett136
  • 21
Message 6 of 38
Re: Broadband
Downstream
11390000003.540256 qam1
21470000003.740256 qam2
31550000003.238256 qam3
4163000000238256 qam4
51710000002.438256 qam5
61790000003.240256 qam6
71870000003.240256 qam7
81950000002.540256 qam8
92030000001.740256 qam9
102110000002.240256 qam10
11219000000240256 qam11
122270000001.740256 qam12
132350000001.540256 qam13
142430000002.240256 qam14
152510000002.240256 qam15
162590000001.740256 qam16
172670000001.540256 qam17
182750000001.240256 qam18
192830000000.740256 qam19
202910000000.538256 qam20
212990000000.738256 qam21
223070000000.540256 qam22
233150000000.538256 qam23
243230000000.238256 qam24
dhackett136
  • 21
Message 7 of 38
Re: Broadband
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1462000004.575512064 qam1
2326000004.45512064 qam3
3393999324.5512064 qam2
4257999014.4512064 qam4
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
dhackett136
  • 21
Message 8 of 38
Re: Broadband
26/07/2020 09:31:27noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/07/2020 09:29:43Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2020 09:36:34criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/07/2020 15:33:30noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/07/2020 10:34:55criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/07/2020 06:21:44noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/07/2020 00:15:39Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/07/2020 23:49:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/07/2020 18:34:48noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/07/2020 18:12:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/07/2020 11:34:5noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/07/2020 11:20:49criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/07/2020 11:20:41noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/07/2020 11:20:34Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/07/2020 11:19:48criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/07/2020 11:10:53criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:42Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:22Warning!MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:22Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
dhackett136
  • 21
Message 9 of 38
Re: Broadband
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 10 of 38
Re: Broadband
Can you please post the second part of your Downstream stats.
