Broadband
My internet speed keeps dropping off in the Great Yarmouth area as from February , anyone else getting these problems from Virgin ?
  • 6.75K
  • 505
  • 884
Legend
Re: Broadband
Have you checked the 'Check Service Status' at the top of the page?
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may not be affecting the area. Be aware that it isn't a manned
How are you connected, Wi-Fi or ethernet cable connection ?
Set up a Broadband Quality Monitor (BQM) at thinkbroadband.com - this will give you an insight into what is happening with the signal at the Hub, it will take a few hours to get any kind of trend showing.
Then
Type 192.168.0.1 (192.168.100.1 in Modem mode) into your browser URL bar and press enter.  When the page appears DO NOT LOG IN but click ‘Check Router Status’. Copy and paste the contents of each tab onto here, a Guru will be along soon to decipher the info.
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
