Are any of your neighbours experiencing a faut?
Try the “check service,” Area status webpage" (link at top right of this forum), also try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues down to postcode level.
If nothing shows on there, try calling it in as a fault again (free on 150 VM line - or 0345 454 1111 others - national rate) and see what they say when they test your connection - after all the issue might be specific to you.
