  • 5
Broadband speeds no more than 30 Mbps
for the last couple of weeks ive had terrible speeds! I'm on the 200mbps connection but never get anything above 40Mbps (wired or wifi)
Ive factory reset my SH3 and still having issues! any ideas? are VM having issues in the NG15 area??
Regards,
Steve Matthews
  • 5
Re: Broadband speeds no more than 30 Mbps
To say im on a VM connection and speed tested to a VM server this is pretty poorTo say im on a VM connection and speed tested to a VM server this is pretty poor
  • 3.51K
  • 567
  • 1.38K
This post might assist in terms of moving things forward a bit.  If the stats are out of spec there's nothing customers can do to fix them, but if you can identify a fault then often that makes getting it fixed a lot easier.
