on 15-01-2023 17:43
Hi I've just had 1gb installed , the tech said use sam knows to check speeds , when I use it , it says 1150 to router but only 350 to pc ? Is that right aren't I mean to get 1150 to pc? Thanks
Answered! Go to Answer
on 15-01-2023 17:45
@darrendriver wrote:Hi I've just had 1gb installed , the tech said use sam knows to check speeds , when I use it , it says 1150 to router but only 350 to pc ? Is that right aren't I mean to get 1150 to pc? Thanks
Wireless or wired device?
on 15-01-2023 17:45
on 15-01-2023 17:46
Hi wired thanks
on 15-01-2023 17:48
on 15-01-2023 17:49
Hi no I just tried what the tech said , just seem strange I get 1150 to router but only 350ish to pc , and its all hard wired
on 15-01-2023 17:53
It could be a limitation of the device or some software (Anti-virus) limiting the speed.
on 15-01-2023 17:54
Is there anything I can do ? Get better Etherley cable ect
on 15-01-2023 17:57
@darrendriver wrote:Is there anything I can do ? Get better Etherley cable ect
Try rebooting in safe mode (with networking) and try another test to rule out software being the issue:
https://www.bleepingcomputer.com/tutorials/how-to-start-windows-10-in-safe-mode-with-networking/
on 15-01-2023 18:02
Ok thanks I'll give it ago and post pack
on 15-01-2023 18:09
Hi in safe mode it's 900 plus , so 3 x faster
