Patricia161
  • 10
Message 1 of 10
Broadband speed
  • Have upgraded package to 350mb download but only getting 80mb download on my iPad how do you get engineer out as every time I phone we go through same procedures and nothing gets better
Richw1982
  • 372
  • 33
  • 89
Fibre optic
Message 2 of 10
Re: Broadband speed
-  Try a pinhole reset to force any updates.  Press and hold reset button on back for 15 seconds then release for 5.  Repeat this 3 times and wait 10 mins for it to load back up.
-  Log into GUI by typing 192.168.0.1 into a web browser then go to
Advanced Settings > Wireless > Wireless Signal
1)  Make sure 2.4 and 5 are enabled.
2)  Scroll to bottom and disable smart Wi-Fi.
3)  Select 20 on 2.4GHz
4)  Select 20/40/80 on 5GHz.
Save settings.
(Wi-Fi will drop out and then re-connect)
Re-enable smart Wi-Fi and save settings again.
Patricia161
  • 10
Message 3 of 10
Re: Broadband speed
If I do this will I have to put password in again for all my devices
  • 3.21K
  • 251
  • 700
Message 4 of 10
Re: Broadband speed
No, only if you change the passwords on the wifi.  Also VM will only accept speed tests via a wired connection direct to the Hub.
Patricia161
  • 10
Message 5 of 10
Re: Broadband speed
Thank you for your reply speeds are up now so everything sorted
  • 24.1K
  • 2.55K
  • 4.37K
Message 6 of 10
Re: Broadband speed
Tell us who and what sorted it ?
Patricia161
  • 10
Message 7 of 10
Re: Broadband speed
It just sorted itself maybe it needed 36hours from when upgrade went through
jem101
  • 1.72K
  • 238
  • 804
Message 8 of 10
Re: Broadband speed
@Patricia161 unfortunately, no once the upgraded config is sent to the hub and it reboot, then the speed change happens immediately, there's no 'settling down' time. This is actually a worry since it hints towards you either having an intermittent connectivity issue or possibly they didn't actually bother to upgrade you for a day. I'll tend towards the former, so keep a check on your connection and come back if you have problems in the future.
Patricia161
  • 10
Message 9 of 10
Re: Broadband speed
Speed seem to sort itself and still working at moment so hopefully no more problem Thanks everyone who tried to help
Steven_L
  • 5.35K
  • 371
  • 543
Message 10 of 10
Re: Broadband speed
Thanks for coming back to us @Patricia161, I'm glad that your speed issues have been sorted.
Please let us know if you need any further assistance.
Regards,
Steven_L
