Thanks for getting back to us RobDavey,
I've been able to locate your account using your forum details, and there does appear to be some prolonged signal level issues.
Appreciate you've mentioned you have rebooted the hub previously, but can you please perform a pin hole reset for me so I can check the levels again?
Alex_Rm
