thenuns
  • 13
Message 1 of 18
Broadband speed
I cannot get to speak with anyone from customer services, just keep getting the turn your router on and off spin.
I'm a 500mb customer yet get no more than 60mb either wired or WiFi.
I believe my hub is broken as all service status and online help checks say there's nothing wrong.
My hub has been restarted more than my 10 year old car!
How on earth can I either get a technician out, or get a new hub sent out.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/acbbf97f8ef2fa2d1467f50f81de21c3521b31b9
conman33158
  • 798
  • 76
  • 105
Superfast
Message 2 of 18
Re: Broadband speed
Are you using a Cat 5e or better cable from the router to the PC?
What speed do you get on https://speedtest.samknows.com/ with direct wired connection from PC/Laptop to router using a Cat 5e cable or better with a 1Gbps Ethernet capable network card?
thenuns
  • 13
Message 3 of 18
Re: Broadband speed
Yes, its a cat 6 cable for a connections. The router is currently in modem mode running a tp link mesh.
The download speeds of 60mbs is the same in router or modem mode. Upload is 37mbs.
As I said reset many times by the reset pin hole, so default settings for router, only changes is to set in modem mode. As I said tho, same download speeds in either mode. These speeds are from Ookoa speed test for both wired and wireless devices
carl_pearce
  • 4.74K
  • 404
  • 711
Superstar
Message 4 of 18
Re: Broadband speed
Could you access your router using http://192.168.0.1/ or http://192.168.100.1 for modem mode. Log in, select the 'Advanced settings / Tools / Network status' option and paste your 'Downstream', 'Upstream', and 'Network Log' tabs? Please copy/paste this data as text, split between multiple posts (Sometimes you have to click 'Post' twice due to an error message).
Create a BQM and post the live link.
thenuns
  • 13
Message 5 of 18
Re: Broadband speed
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
402750000
-4
40
256 qam
30
2
202750000
-1.5
40
256 qam
9
3
210750000
-1.5
40
256 qam
10
4
218750000
-1.9
40
256 qam
11
5
226750000
-2
40
256 qam
12
6
234750000
-2.4
40
256 qam
13
7
242750000
-2.7
40
256 qam
14
8
250750000
-2.2
40
256 qam
15
9
258750000
-1.9
40
256 qam
16
10
266750000
-1.9
40
256 qam
17
11
274750000
-1.9
40
256 qam
18
12
282750000
-2
40
256 qam
19
13
290750000
-2.2
40
256 qam
20
14
298750000
-2
40
256 qam
21
15
306750000
-1.7
40
256 qam
22
16
314750000
-1.7
40
256 qam
23
17
322750000
-2
40
256 qam
24
18
330750000
-2.4
40
256 qam
25
19
370750000
-3.2
40
256 qam
26
20
378750000
-3.2
40
256 qam
27
21
386750000
-3.5
40
256 qam
28
22
394750000
-3.7
40
256 qam
29
23
410750000
-4
40
256 qam
31
24
418750000
-4
40
256 qam
32
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.3
83
4
2
Locked
40.3
1223
153
3
Locked
40.9
1710
91
4
Locked
40.9
1537
816
5
Locked
40.3
250
2128
6
Locked
40.3
1852
13
7
Locked
40.9
1558
14
8
Locked
40.9
502
3
9
Locked
40.9
226
0
10
Locked
40.9
530
1
11
Locked
40.9
1206
0
12
Locked
40.3
939
11
13
Locked
40.3
485
0
14
Locked
40.3
1695
0
15
Locked
40.9
1726
7
16
Locked
40.9
1290
20
17
Locked
40.9
477
13
18
Locked
40.9
1380
11
19
Locked
40.9
776
24
20
Locked
40.3
149
8
21
Locked
40.3
106
7
22
Locked
40.9
95
8
23
Locked
40.3
82
1
24
Locked
40.9
103
0
thenuns
  • 13
Message 6 of 18
Re: Broadband speed
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
53700000
49.8
5120
64 qam
6
2
46200000
49.3
5120
64 qam
7
3
39400000
48.8
5120
64 qam
8
4
60300000
50
5120
64 qam
5
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
thenuns
  • 13
Message 7 of 18
Re: Broadband speed
Time
Priority
Description
31/01/2021 11:41:30
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/01/2021 11:27:59
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/01/2021 21:59:19
critical
28/01/2021 02:46:18
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/01/2021 20:30:39
Warning!
25/01/2021 15:15:7
critical
25/01/2021 14:48:10
Warning!
25/01/2021 14:40:55
notice
25/01/2021 14:40:25
Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:37
critical
25/01/2021 14:30:5
Warning!
25/01/2021 06:14:29
critical
24/01/2021 21:44:29
Error
22/01/2021 18:03:49
notice
22/01/2021 18:03:34
Warning!
01/01/1970 00:01:37
critical
22/01/2021 17:09:56
notice
22/01/2021 17:09:21
Warning!
01/01/1970 00:01:38
critical
22/01/2021 16:53:21
Warning!
thenuns
  • 13
Message 8 of 18
Re: Broadband speed
Those tests done in modem mode. Speedtest (online) results consistently tell me 37up and between 50-75 down. All cables cat6. Tests done directly from modem, hard wired to deco mesh, through power line adapters and over mesh WiFi. Always the same results full speed up 10% of what I'm supposed to get down 🤷
conman33158
  • 798
  • 76
  • 105
Superfast
Message 9 of 18
Re: Broadband speed
You need to create the BQM as asked.
Please setup a Broadband Quality Monitor (BQM) at thinkbroadband.com. Just click on Create a new monitor.
Post a 'Live Link' to your BQM on here asap.
Under your graph you just created Click (Share Live Graph) then click generate.
Copy the text in the Direct Link box and paste it on here
thenuns
  • 13
Message 10 of 18
Re: Broadband speed
https://www.thinkbroadband.com/broadband/monitoring/quality/share/acbbf97f8ef2fa2d1467f50f81de21c352...
