Insect73
Broadband speed
Hi,anyone know why my internet speed seems to be 72mbps all the time?I pay for the 350 but have never been there. It seems pointless paying for the 350 when all i get is 72!?
Thanks if you know
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Broadband speed
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Broadband speed
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
