Lullykid
Broadband speed
Really slow speed . Have tried testing equipment and get message ‘we are trying to sort this out for you ‘  This has been for over a week now .
Have tried factory resetting hub - no difference Checked for black spots with connect app - all great . speed sometimes struggles to make double figures
Some help would be appreciated
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Broadband speed
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Broadband speed
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Broadband speed
Can you please
