kelvinguy85
  • 5
Broadband speed
I pay for gigabit and currently only getting 100mbps down or less sometimes I have restarted v4 router all ethernet cables are cat 6 and trying to get answers is like pulling teeth
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Broadband speed
The speeds you are getting are indicative of a Network Interface Card (NIC) set at 100/100 whereas it should be set to 1000/1000.
Can you go into the device settings and check ?
kelvinguy85
  • 5
Re: Broadband speed
My nic card is set for 10/100/1000 I have already checked that
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Broadband speed
Try a different cable.
If that doesn't work try a different ethernet port on the Hub 4.
