Mckay64
Broadband speed
My broadband speed about 200mbps but upstairs in my room it tests between 15-30 mbps
i have rebooted router
thanks colin
Anonymous
Not applicable
Re: Broadband speed
Wireless or wired connection?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Broadband speed
IP provided Hubs are renowned for their poor Wi-Fi, and at the best of times Wi-Fi is a fickle beast that can be affected by numerous things such as distance from the Hub,  building construction, other electronic devices, neighbouring Wi-Fi, basically all sorts.
VM supply to the Hub, after the Hub it is up to you.
Many on here, myself included advocate the use of a third party Gigabit capable Wi-Fi router or Mesh system.
