Briant001
Just joined
Broadband speed very slow
hi, my broadband speed is practically non existent down to 1 mbs.
The whole surrounding area has slow speed also in other households who are also struggling.
In the last 24 hours I’ve spoken to virgin media several times and wasted hours on the phone. Have established There is nothing wrong with my equipment And is external issue, but they are not acknowledging this.
this is very frustrating especially during lockdown as kids can’t use internet for gaming etc.
can any one help as I’m sick of getting nowhere on the phone.
thanks
DJ_Shadow1966
  • 6.86K
  • 1.31K
  • 1.9K
Re: Broadband speed very slow
Hello
Thank for joining in on the forum, we will try the best to get your issue resolved.
How are you doing the speedtest is it either wired or wireless, wired is always the best option. If wired can you please do the following :-
Can you please post your network stats from the hub
Open a Web browser (e.g. Internet Explorer) and enter the address http://192.168.0.1
Note: If you have enabled Modem Mode on your Hub 3.0 you will need to use 192.168.100.1 instead.
Posting the stats by copy and paste will remove all personal information so no breaches.
Do not login but click on where it says "Check Router Stats" and then copy and post from the following 4 tabs, Downstream, Upstream, Configuration and Network logs (if they are pasted then all personal information is * out) and we can check your power level, also while you about that can you please go around and check that all connectors to VM equipment are hand tight. Also while doing this please check for any damage to cable, or un-terminated connection without either coax or a terminator.
Also please run "Check service status" at the top right of this forum and call 0800 561 0061 to check for local issues.
Also one think you can do is too signup at https://www.thinkbroadband.com/broadband/monitoring/quality and setup a broadband quality monitor which will keep an eye on you connection by sending a small amount of data to the hub asking if it still on.
Regards Mike
