Hardyminardi
  • 9
Message 1 of 14
Broadband speed stuck at around 2mbps
Hi. My speed has been stuck at 1 to 2mbps for about three days now. I have tried everything like resetting the router via the reset switch, plugging in a different router. It is on all devices in the house and not just one. Copy and paste of router info.
Refresh data
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-rtsl10016u-b.cm
SFID 186744
Max Traffic Rate 117000047
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 186743
Max Traffic Rate 10500047
Max Traffic Burst 16320
Min Traffic Rate 0
Max Concatenated Burst 16320
Scheduling Type BestEffort
Refresh data
1 39400000 4.5 5120 64 qam 6
2 25800000 4.525 5120 64 qam 8
3 46200000 4.525 5120 64 qam 5
4 32600000 4.5 5120 64 qam 7
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
Refresh data
1 483000000 -8 36 256 qam 32
2 203000000 -2.7 36 256 qam 9
3 211000000 -3 37 256 qam 10
4 219000000 -3.4 36 256 qam 11
5 227000000 -4.5 36 256 qam 12
6 235000000 -6 36 256 qam 13
7 243000000 -5.7 36 256 qam 14
8 251000000 -5 36 256 qam 15
9 259000000 -4.7 36 256 qam 16
10 267000000 -4 36 256 qam 17
11 275000000 -3.7 37 256 qam 18
12 283000000 -4.2 37 256 qam 19
13 291000000 -4.7 36 256 qam 20
14 299000000 -4.5 36 256 qam 21
15 307000000 -4.2 37 256 qam 22
16 315000000 -4 37 256 qam 23
17 323000000 -3.5 37 256 qam 24
18 427000000 -6.5 37 256 qam 25
19 435000000 -6.7 36 256 qam 26
20 443000000 -6.9 36 256 qam 27
21 451000000 -7 36 256 qam 28
22 459000000 -7.2 36 256 qam 29
23 467000000 -7.5 36 256 qam 30
24 475000000 -8 36 256 qam 31
1 Locked 36.6 14 0
2 Locked 36.6 5 0
3 Locked 37.3 0 0
4 Locked 36.6 0 0
5 Locked 36.6 7 0
6 Locked 36.6 9 0
7 Locked 36.3 4 0
8 Locked 36.6 7 0
9 Locked 36.6 0 0
10 Locked 36.6 7 0
11 Locked 37.3 0 0
12 Locked 37.3 5 0
13 Locked 36.3 4 0
14 Locked 36.6 17 0
15 Locked 37.3 4 0
16 Locked 37.6 0 0
17 Locked 37.3 0 0
18 Locked 37.3 5 0
19 Locked 36.6 6 0
20 Locked 36.6 13 0
21 Locked 36.6 4 0
22 Locked 36.6 5 0
23 Locked 36.3 5 0
24 Locked 36.6 6 0
Cable Modem Status
Item Status Comments
483000000
Locked
Ranged Upstream Channel (Hz)
39400000
Locked
Provisioning State
Online
Refresh data
03/09/2020 18:08:47 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/09/2020 17:45:24 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:33 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/09/2020 16:49:26 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/09/2020 13:34:46 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/09/2020 12:08:22 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/09/2020 11:31:47 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/09/2020 11:31:46 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:32 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:02:20 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:31 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/09/2020 13:49:27 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 15:51:15 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/08/2020 11:12:45 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/08/2020 11:12:45 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/08/2020 11:12:22 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/08/2020 11:12:22 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/08/2020 11:12:5 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/08/2020 11:12:5 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/08/2020 11:09:33 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Anonymous
Not applicable
Message 2 of 14
Re: Broadband speed stuck at around 2mbps
A number of your downstream channels are out of spec on their power level (-6 to +10 is in spec).
Do you have a device, like below, plugged in between your HUB and cable to the wall socket?
Hardyminardi
  • 9
Message 3 of 14
yes, I think I do.
Hardyminardi
  • 9
Message 4 of 14
Yes I do. It is an FPA 6 DB
Hardyminardi
  • 9
Message 5 of 14
I unplugged it and plugged the cord in without it and for a few seconds I had 100 plust mbps. Now it is back down to 1 - 2mbps.
Anonymous
Not applicable
Message 6 of 14
Could you post a fresh set of stats with it removed?
Hardyminardi
  • 9
Message 7 of 14
Router status
Status
Downstream
Upstream
Configuration
Refresh data
Cable Modem Status
139000000
Locked
39400000
Locked
Provisioning State
Online
Refresh data
1 139000000 6.6 38 256 qam 1
2 147000000 6.4 37 256 qam 2
3 155000000 6.4 38 256 qam 3
4 163000000 6.5 38 256 qam 4
5 171000000 6.3 38 256 qam 5
6 179000000 5.6 37 256 qam 6
7 187000000 4.9 37 256 qam 7
8 195000000 4.1 37 256 qam 8
9 203000000 3.9 37 256 qam 9
10 211000000 3.5 37 256 qam 10
11 219000000 3.2 37 256 qam 11
12 227000000 2 37 256 qam 12
13 235000000 0.5 37 256 qam 13
14 243000000 0.9 37 256 qam 14
15 251000000 1.5 37 256 qam 15
16 259000000 2.2 37 256 qam 16
17 267000000 2.7 37 256 qam 17
18 275000000 3.2 37 256 qam 18
19 283000000 2.7 37 256 qam 19
20 291000000 2.2 37 256 qam 20
21 299000000 2.4 37 256 qam 21
22 307000000 2.7 37 256 qam 22
23 315000000 3 37 256 qam 23
24 323000000 3.5 37 256 qam 24
1 Locked 38.9 5 0
2 Locked 37.6 6 0
3 Locked 38.6 5 0
4 Locked 38.6 6 0
5 Locked 38.6 7 176
6 Locked 37.6 5 0
7 Locked 37.6 6 0
8 Locked 37.6 5 0
9 Locked 37.6 5 0
10 Locked 37.6 6 0
11 Locked 37.3 5 0
12 Locked 37.6 5 0
13 Locked 37.6 8 0
14 Locked 37.3 1 0
15 Locked 37.6 5 0
16 Locked 37.6 4 0
17 Locked 37.3 5 0
18 Locked 37.6 6 0
19 Locked 37.6 5 0
20 Locked 37.6 0 0
21 Locked 37.6 19 0
22 Locked 37.6 5 0
23 Locked 37.3 0 0
24 Locked 37.6 0 0
Refresh data
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1 39400000 4.45 5120 64 qam 6
2 25800000 4.475 5120 64 qam 8
3 46200000 4.5 5120 64 qam 5
4 32600000 4.45 5120 64 qam 7
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
Refresh data
Network access
Allowed
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
SFID 186778
Min Traffic Rate 0
SFID 186777
Min Traffic Rate 0
Refresh data
Anonymous
Not applicable
Message 8 of 14
The power levels look better however the errors in the network log still point to an issue.
Hardyminardi
  • 9
Message 9 of 14
Thank you. Any ideas? I even plugged the router directly into the cable coming into the wall. split second of 100+mbps and then back down. The account is changing over to as different name on the 7th, when a technician is coming to install another router. Could this have something to do with it? There should be no break in coverage and it is going to be on a 200mbps sevice with both contracts. Funnily enough, since unplugging the unit you advised, I now have two instances of my network, one with simply a '2' added next to it but the same SSID otherwise.
Anonymous
Not applicable
Message 10 of 14
Unplugging that device wouldn't have created a second SSID.
Maybe ask the technician to investigate when they arrive?
