SpaceHunter
Broadband speed slower than expected
Greetings,
I am currently using a M500 fibre, however the speedtest by ookla gives me a result of around 250Mbps only. The upload speed is at 36Mbps as expected though. I am connecting via Wifi using the Virgin provided router?
What's going on? Shall I contact an engineer?
Thanks for helping me!
Tags (1)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Broadband speed slower than expected
What speed do you get at >> speedtest.net << with a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
SpaceHunter
This is ... I don't know how to describe my feelings...
But anyway, thank you for your answer, I was suspecting if the bandwidth reached the router's bottleneck. Indeed it is, I've ordered a cable over the weekend. Now the speed is 530Mbps. Thanks.
The router itself is actually provided by virgin for free. I am wondering if I should return this and buy a new router online. I would like to hear your suggestion. Thank you very much, I appreciate this!
Anonymous
Not applicable
You can't use your own router as a modem, only the one supplied by VM.
You can, however put the HUB in modem mode and buy a third party router and connect the two with an ethernet cable.
