  • 86
  • 14
Dialled in
Message 1 of 10
Broadband speed slower since upgrade to 100Mbps
I was previously on a 50mbps connection. Whilst I very rarely got near 50Mbps I could normally rely on getting something around 35mbps.
VM gave me a free upgrade to 100mbps in February. They sent me a letter saying that:-
"We estimate that at peak times the download speed to your Virgin Media Hub will range between 108Mbps and 111Mbps and your upload speed will be 10Mbps. The minimum download speed to you Virgin Media Hub shouldn't fall below 54Mbps."
Since this "upgrade" my average download speed has been worse than it was before. I'm now lucky to get 20-25 mbps, nevermind 54 Mbps.
Can anyone help?
  • 2.48K
  • 156
  • 643
Problem sorter
Message 2 of 10
Re: Broadband speed slower since upgrade to 100Mbps
How are you testing the speed? The figures you're quoting sound like 2.4Ghz WiFi. You'll need to run a wired speedtest just to check the true speed that is being delivered and to rule out (or in) WiFi problems.
  • 86
  • 14
Dialled in
Message 3 of 10
OK. So I plugged my laptop directly into my SuperHub3.
Performed the speed test and got 110Mbps download and 9.9 Mbps upload (more like it).
So why has the WiFi got so pants?? Even when sat right next to the hub I'm only 22Mbps download.
  • 86
  • 14
Dialled in
Message 4 of 10
Done a bit more digging...
Used the Wifi Analyzer app on my phone and discovered that there was no 5GHz signal from the Hub.
Logged on and found these settings:-
  • 86
  • 14
Dialled in
Message 5 of 10
2.4 GHZ - enabled, Channel = Manual
5 GHz - disabled
Smart WiFi - Disable Channel Optimization
I've not done this, and nobody else in the house knows how to do this.
How could this happen?
  • 1.57K
  • 79
  • 158
Message 6 of 10
Hi DonnyDriver
Can I ask if you've downloaded the Virgin Media 'Connect' app?
Lee_R
  • 20.96K
  • 1.14K
  • 2.7K
Message 7 of 10
Re-enable the 5Ghz band and see how it is after that.
  • 1.57K
  • 79
  • 158
Message 8 of 10
Adding to what @gary_dexter advice please can advise us how things went?
Lee
  • 86
  • 14
Dialled in
Message 9 of 10
I enabled the 5Ghz on my router.
I wouldn't say it's made a huge difference though. Speeds are sporadic and averaging still around 25 Mbps
  • 3.57K
  • 196
  • 548
Community elder
Message 10 of 10
Does your laptop have a suitable WiFi card?
As a test, turn off 2.4GHz in the Hub and see if the laptop still connects on 5GHz.
