eighthsage
  • 12
Broadband speed, phone and more...
I upgraded my broadband speed to 350mbps yesterday and added maxit tv.
The tv upgrade has gone through.   Not long after that my modem was rebooted and I had assumed it would go to 350 but it hasn't.
My phone line has gone down (this could be unrelated) and your 0345 454 1111 number is faulty at the moment.
Can you help?
Tags (1)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Broadband speed, phone and more...
Try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Please do this before the Hub Data
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
Please do not use screen shots.
