on 23-04-2022 20:59
My broadband speed is consistently slower than the advertised speed. I was on m350 and recently upgraded to m500 but didn't see any changes in speed. I joined 02 and was upgraded to Gbit broadband but still my download speed hasn't changed, my upload speed has now increased. I have tried multiple devices and wired connections buy always get the same speeds.
I have the hub 4 in modem mode and use Deco mesh WiFi. I have no issues with my phone on virgin broadband at my in-laws so it's clearly capable of the speeds however at home it won't go over 250mb
I have tried the connections tests etc but it just tells me to restart hub which I have multiple times.
Anyone got any ideas?
on 24-04-2022 13:16
@alexdc12 your downstream power levels are way too high, you’ll need to either have a attenuator fitted or your connection moved to a different tap in the cabinet. Either way it’s a technician visit, I’m afraid.
on 24-04-2022 13:18
I do have a 3b attenuator but with or without that my download speeds seem the same.
How do I get a engineer out on the basis of this information just ring up and reference this post?
on 24-04-2022 13:33
Closer to 6 dB needed to just get the levels into spec and even then they’ll be at the upper end of the normal accepted range.
I’d just wait for a member of the forum team to come across this thread and offer to get in contact by direct message. They’ll be able to book a visit.
on 24-04-2022 16:47
Hi @alexdc12
Thanks for posting on our community forum!
Sorry to hear about your issue, I am going to drop you a private message now to collect some more details, please keep an eye on your inbox.
on 24-04-2022 17:18
Its going to the interesting or coincidence that just dropping the power levels will fix this.
on 01-05-2022 06:43
Engineer fitted a 10db attenuator I now get slight faster speed but not even halfway to the 1gbps it should be
on 01-05-2022 08:20
What did the technician say about your speeds? Did you not ask him about it while he was there?
on 01-05-2022 08:24
He said, the signal is too strong he's fitted the attenuator but to leave it for a while to settle down as it will need to rescan all the channels etc but it should be ok now and to text him if I have any problems which I have done.
on 18-06-2022 13:01
Can you get back on this one please? Engineer is ignoring my texts now. Service speed is still rubbish. It improved a little but not much
on 19-06-2022 00:39
Connect PC to hub in modem mode and do a speed test
