alexdc12
  • 33
  • 7
Message 1 of 23
Broadband speed only 20-25% of advertised speed
My broadband speed is consistently slower than the advertised speed. I was on m350 and recently upgraded to m500 but didn't see any changes in speed. I joined 02 and was upgraded to Gbit broadband but still my download speed hasn't changed, my upload speed has now increased. I have tried multiple devices and wired connections buy always get the same speeds.
I have the hub 4 in modem mode and use Deco mesh WiFi. I have no issues with my phone on virgin broadband at my in-laws so it's clearly capable of the speeds however at home it won't go over 250mb
I have tried the connections tests etc but it just tells me to restart hub which I have multiple times.
Anyone got any ideas?
jb66
  • 13.01K
  • 991
  • 1.95K
Message 2 of 23
Re: Broadband speed only 20-25% of advertised speed
Can you run a test wired direct to the hub and not using your own kit so we can work out if its a VM issue or your own equipment that's not up to the job
alexdc12
  • 33
  • 7
Message 3 of 23
My hub is in modem mode so WiFi is off on the hub, as I stated I have tried wired and wireless and get the same speeds.
My neighbour has just told me he had the same issue and it was the coax splitter that needs changing.
jb66
  • 13.01K
  • 991
  • 1.95K
Message 4 of 23
Until you put the Hub back into router mode and test via https://www.samknows.com/realspeed/ we cant help you. There is a high probability of it being your Deco thats the bottleneck
alexdc12
  • 33
  • 7
Message 5 of 23
Hub is back in modem mode but that site won't work?
I have tried wired to hub and am still getting same bottle neck speeds as before.
Same on WiFi
alexdc12
  • 33
  • 7
Message 6 of 23
found a diff link to that site, here is the results on my laptop wired direct to hub. i think we can rule the deco out here
ozsat
  • 5.02K
  • 348
  • 987
Superstar
Message 7 of 23
The thing is you are still measuring your own network speed from the computer to the hub.
Samknows Realspeed will tell you if the problem is on the VM side or the hub itself.
1.2Gb/55Mb in Oxford (area 31) using SH5
alexdc12
  • 33
  • 7
Message 8 of 23
But the realspeed won't work? Says I'm not connected to a virgin WiFi network but I am.
jb66
  • 13.01K
  • 991
  • 1.95K
Message 9 of 23
The realspeed website only works in router mode and not modem mode.
If you could post your signal levels of your hub we can look at that also
alexdc12
  • 33
  • 7
Message 10 of 23
I changed to router mode and it didn't work, that's when I did the screenshot above
2533100000020.09999840.366287QAM25625
1021100000019.90000240.946209QAM25610
1121900000019.80000340.366287QAM25611
1222700000019.59999840.366287QAM25612
1323500000019.50000040.366287QAM25613
1424300000019.40000240.366287QAM25614
1525100000019.40000240.946209QAM25615
1625900000019.50000040.366287QAM25616
1726700000019.59999840.366287QAM25617
1827500000020.00000040.366287QAM25618
1928300000020.40000240.946209QAM25619
2029100000020.50000040.366287QAM25620
2129900000020.30000340.366287QAM25621
2230700000019.80000340.366287QAM25622
2331500000019.59999840.366287QAM25623
2432300000019.69999740.946209QAM25624
2633900000020.50000040.366287QAM25626
2734700000020.69999740.946209QAM25627
2835500000020.50000040.366287QAM25628
2936300000020.09999840.366287QAM25629
3037100000019.69999740.946209QAM25630
3137900000019.30000340.366287QAM25631
3238700000019.09999840.366287QAM25632
3339500000019.09999840.946209QAM25633
3440300000019.30000340.366287QAM25634
3541100000019.50000040.366287QAM25635
3641900000019.50000040.946209QAM25636
3742700000019.69999740.366287QAM25637
3843500000019.59999840.366287QAM25638
3944300000019.59999840.366287QAM25639
4045100000019.40000240.366287QAM25640
3.0 Downstream channels
25Locked40.366287
0
10Locked40.94620900
11Locked40.36628700
12Locked40.36628700
13Locked40.36628700
14Locked40.36628700
15Locked40.94620900
16Locked40.36628700
17Locked40.36628700
18Locked40.36628700
19Locked40.94620900
20Locked40.36628700
21Locked40.36628700
22Locked40.36628700
23Locked40.36628700
24Locked40.94620900
26Locked40.36628700
27Locked40.94620900
28Locked40.36628700
29Locked40.36628700
30Locked40.94620900
31Locked40.36628700
32Locked40.36628700
33Locked40.94620900
34Locked40.36628700
35Locked40.36628700
36Locked40.94620900
37Locked40.36628700
38Locked40.36628700
39Locked40.36628700
40Locked40.36628700
