Emily0901
  • 13
Message 1 of 26
Broadband speed not what I am paying for
I am paying for m350 but consistently I am NOT getting anywhere near what I should be getting
My Download speeds over the last 5 days measured at different times is
Download 28.57mbps
Upload 24.18
Really bad when trying to zoom or using teams
Pars
  • 136
  • 20
  • 29
Superfast
Message 2 of 26
Re: Broadband speed not what I am paying for
Is this over a wired or wireless connection?
M350 over FTTP
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 3 of 26
Please do this before posting the Hub Data
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 4 of 26
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
Please do not use screen shots.
Emily0901
  • 13
Message 5 of 26
Bqm link posted
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 6 of 26
@Emily0901 wrote:
Bqm link posted
Where ?
Emily0901
  • 13
Message 7 of 26
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 8 of 26
Your >> BQM << is looking very good compared to most that have been posted just recently.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 9 of 26
Can you post your Hub data please.
Emily0901
  • 13
Message 10 of 26
