vonconway
Message 1 of 5
Broadband speed not reaching guaranteed minimum
Hi, I have M250 package and the speeds for download & upload are way off the guaranteed minimum. Was on the phone with VM but they said that I would only be getting 75Mbps for either of those max, but I queried that it should be closer to the 124Mbps, they then hung up/got cut off. I have the SH3 running in modem mode, I have Ubiquiti UniFi USG Enterprise Security Gateway Broadband Router connected to the SH3 and a (Netgear) switch connected to that. The test was with a wired in Mac. The support have previously asked me to do a factory reset, which I did, but doesnt seem to change anything. Previously when tested I have had up to  65 on the download speed and 21 on the upload.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 5
Re: Broadband speed not reaching guaranteed minimum
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
SCA1972
  • 5.92K
  • 662
  • 2.02K
Message 3 of 5
@vonconway  Your speed test image has been rejected as it contains your WAN IP address and this is against the forum rules, to protect your privacy.  If you use the share options on the speed test page you can add a link or embed an image of your results without your IP address.
As VM UK don't have an M250 package, are you on the M200 package or perhaps a VM Ireland customer?  Staff here can only support UK customers.
Have you recently upgraded the OS on the Mac?
A recent poster has discovered they get slower speeds with Big Sur than they do with Catalina:
https://community.virginmedia.com/t5/Speed/Re-Deteriorating-Broadband-speeds/m-p/4486615#M249366
If it is not the OS, then have you tired a wired connection direct to the Hub 3 in modem mode?  VM can't support third party kit so the first thing the staff here would ask you to do id to test without your own kit to rule out any issues.
______________________
Scott
My setup: VM TV box, M350 Fibre broadband with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
vonconway
Message 4 of 5
Hi, yes, correct it is the M200 package. I have updated to Big Sur in the last few weeks too. As per yours & @MikeRobbo suggestion, I checked the speed directly wired into the SH3, and actually it is a lot quicker. 208Mbps download. Thanks Both. So now I need to figure out how not to lose so much speed between the SH3 and everything connected
SCA1972
  • 5.92K
  • 662
  • 2.02K
Message 5 of 5
Well at least you now know that VM are delivering the correct speed. Good luck in tracking down the bottleneck on your LAN.
Scott
