Damnsilly
Broadband speed not as good as 4g
My broadband speed has never got above 40mbps download/20mbps upload even though I pay for 200mbps, regardless of whether I use wifi or hardwire into the router, doesn't matter what device. What is worse is that my phone is actually better when I turn the wifi off and use 4g 75mbps download/25mbps upload, surely this can't be right?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Broadband speed not as good as 4g
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
