antaylwin
Message 1 of 5
Broadband speed much lower than advertised
On M200 fibre, but getting download speed of 80Mbpsonly. How can I improve?
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
259000000
0.4
37
256 qam
16
2
251000000
0.2
37
256 qam
15
3
267000000
0.5
37
256 qam
17
4
275000000
0.4
38
256 qam
18
5
283000000
0.7
38
256 qam
19
6
291000000
1
38
256 qam
20
7
299000000
1.5
38
256 qam
21
8
307000000
1
38
256 qam
22
9
315000000
0.7
38
256 qam
23
10
323000000
1
38
256 qam
24
11
331000000
1.4
38
256 qam
25
12
371000000
0.9
38
256 qam
26
13
379000000
0.7
38
256 qam
27
14
387000000
0.5
38
256 qam
28
15
395000000
0.7
38
256 qam
29
16
403000000
0.9
38
256 qam
30
17
411000000
0.7
38
256 qam
31
18
419000000
0.4
38
256 qam
32
19
427000000
0.4
38
256 qam
33
20
435000000
0.5
38
256 qam
34
21
443000000
0.2
38
256 qam
35
22
451000000
-0.2
38
256 qam
36
23
459000000
-0.5
38
256 qam
37
24
467000000
-0.7
38
256 qam
38
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
37.6
80756
8875
2
Locked
37.6
92677
9403
3
Locked
37.6
67200
6434
4
Locked
38.6
58646
5275
5
Locked
38.6
42551
3770
6
Locked
38.6
35497
3271
7
Locked
38.6
38892
2693
8
Locked
38.9
33842
1748
9
Locked
38.6
25851
2742
10
Locked
38.9
20407
1743
11
Locked
38.9
18312
990
12
Locked
38.9
11825
347
13
Locked
38.6
31849
343
14
Locked
38.9
9878
182
15
Locked
38.6
9679
169
16
Locked
38.9
14426
164
17
Locked
38.6
9223
84
18
Locked
38.9
7265
144
19
Locked
38.9
7296
88
20
Locked
38.9
5991
59
21
Locked
38.9
5488
22
22
Locked
38.9
6154
41
23
Locked
38.6
5126
32
24
Locked
38.6
5027
35
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
53700000
45.5
5120
64 qam
2
2
60300000
46
5120
64 qam
1
3
39400000
44.8
5120
64 qam
4
4
46200000
45.3
5120
64 qam
3
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
4
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
antaylwin
Message 2 of 5
Re: Broadband speed much lower than advertised
Networl log:
Time
Priority
Description
05/12/2020 16:24:29
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/12/2020 16:23:48
Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/12/2020 13:25:53
notice
05/12/2020 13:24:27
Warning!
04/12/2020 00:14:58
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/12/2020 12:15:48
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/12/2020 23:23:49
critical
29/11/2020 16:51:54
Warning!
25/11/2020 23:24:32
Error
25/11/2020 19:48:9
notice
23/11/2020 10:41:39
critical
23/11/2020 10:41:0
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/11/2020 10:36:39
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/11/2020 10:36:35
Warning!
23/11/2020 10:36:35
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/11/2020 10:36:35
Warning!
23/11/2020 10:36:35
critical
23/11/2020 04:42:0
critical
22/11/2020 10:25:27
notice
22/11/2020 10:12:37
Warning!
Anonymous
Not applicable
Message 3 of 5
is that by wireless or a wired connection?
antaylwin
Message 4 of 5
wired - ethernet to router
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 5 of 5
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
then
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
