Sue81
Message 1 of 5
Broadband speed low
Why since my broadband changed to M350, am I now only getting approx 50mp
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 5
Re: Broadband speed low
How are you connecting Wi-Fi or ethernet cable ?
What is your connection like with a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Buffer6
  • 10.37K
  • 91
  • 610
Hero
Message 3 of 5
What was your speed package before upgrading?
Sue81
Message 4 of 5
It's the same speed with both ethernet and WiFi, when I was on M200 speed I was getting approx 145
Anonymous
Not applicable
Message 5 of 5
Could you access your router using http://192.168.0.1/ or http://192.168.100.1 for modem mode . Don't log in, select the 'Check Router Status' option and paste your 'Downstream', 'Upstream', and 'Network Log' tabs?
