Jcc15
Message 1 of 7
Broadband speed issues
I recently started my virgin broadband connection and have had poor performance since day one. I work from home and my previous provider (BT) didn’t struggle with speed at any time. I’m on M100, but speed test produces between 20-40mbps, which explains why zoom, FaceTime calls drop/fail connecting.
A separate issue is the installation, the engineer advised the cable was faulty and needed replacement, so he connected it to next doors..this apparently wouldn’t effect my speed, but you can understand my reservation. I was advised this would be fixed/I would be contacted, this has not happened.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 7
Re: Broadband speed issues
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 7
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 7
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
Jcc15
Message 5 of 7
Thank you. I tried that but there is no option for ‘Check Router Status’
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 6 of 7
That probably means that you haven't been through the initial Hub Setup.
Log in, go through the set up, logout then try again.
Jcc15
Message 7 of 7
Thank you. I called tech support and it was all fixed with a pin hole reset. Apparently an engineer had previously given the tip that routers can “clogged” up (similar to deleting cache) and this will dramatically improve speed. It did just that, going from 20-30mbps up to 94mbps, which it has remained at since.
