KevinHand
Just joined
Broadband speed issues
We are paying for 200M speed but only getting 50M and that is when it is working. tried ALL resets and everything online - which is very hard with a rubbish intermittent connection!! How do you actually talk to a tech person or arrange for an engineer?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Broadband speed issues
How are you connecting your device, Wi-Fi or ethernet cable ?
It can be difficult diagnosing problems without some basic information.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
HavencroftKev
  • 325
  • 11
  • 100
Fibre optic
May I ask what device you are using to do a speed test, and are you using a wifi or a wired connection?
