Robbo600
  • 7
Broadband speed issue
Hi all
ive put my hub 3 into modem mode and connected a ton link vr2800 and all was fine flying at good speed, more than the 350 deal I’m on.
last night it’s dropped down to around 50 , rung support and reset everything , got cut off the call.
still running slow this morning, any ideas people ?
many thanks
  • 6.81K
  • 592
  • 1.78K
Re: Broadband speed issue
Try checking with Area faults on 0800 561 0061 or if you have a VM landline 150 as small local faults are not listed on the VM status page.
Post your power levels and network log from the Hub and setup a BQM here www.thinkbroadband.com/ping
You could also try a factory reset, as below, on the Hub and do a speed test before putting back in modem mode.
Remove any ethernet cables from the Hub and hold the pinhole reset switch for 60 seconds. Do NOT reboot the Hub, just let it do it's thing. Note you will need the passwords from the bottom of the Hub afterwards, so make sure they are legible.
