ajvgriff
Message 1 of 5
Broadband speed is poor.
My wired and Wi-fi speed have been awful. I use a wired connection to work and need a VPN to connect to my work.
When I perform Speedtests on both my work and personal laptop, I regularly get download speeds <10 mbps, and uploads of <1 mbps. The fastest I’ve gotten was actually today and I managed to get the heady heights of 39 mbps. Wi-fi is much worse. I’m having to use my 4G to get a regular connection. I was instructed to write this topic by a Virgin media representative on twitter.
Tags (1)
Anonymous
Not applicable
Message 2 of 5
Re: Broadband speed is poor.
how do you connect wireless or a wired connection?
Gareth_L
  • 6.18K
  • 379
  • 675
Message 3 of 5
Hello ajvgriff
Sorry to hear this is happening
I have had a look at a few things from here and all downstream and upstream levels are in sync.
No work in the area that may be causing this issue either
Can you try a wired speed test on your personal equipment and not the VPN
Gareth_L
ajvgriff
Message 4 of 5
Sorry, I only saw this recently. Things appear to have improved and I haven’t had any issues. That being said I’ve tried to do a speed test and it gives me a socket error on the upload? There is no issue with my network configuration on my laptop so not sure why this is happening.
Paul_DN
  • 5.86K
  • 344
  • 622
Message 5 of 5
Hi ajvgriff,
Thank you for coming back to us in our community and thank you for the update.
I am glad to hear things have improved, since your last post have you been able to run a speed test, are you using speedtest.net ?
Paul.
