nanahoho
  • 6
Message 1 of 11
Broadband speed has been poor for months
Hello,
I've been with Virgin Media for years, and recently upgraded to a 200mbps package roughly seven months ago and have never had a strong download speed.  I check the connection every so often and not once has it been above the 38mbps via ethernet. I feel this is considerably lower than expected. I just wanted reassurance that this is definitely lower than expected from this package.
I have tried wired connections, moving the hub about as well as restarting it, disconnecting all devices and doing additional speed tests. I just wanted to confirm I was given the right speed?
Any response is appreciated thanks.
Hub 3.0:
Max Traffic Rate402500089
SpeedTest:
Ping15ms
Download Speed36.72Mbps
Upload Speed36.79Mbps
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 2 of 11
Re: Broadband speed has been poor for months
Your images are not showing because they need authorizing.
Can you load them to a hosting service then post the links on here please.
nanahoho
  • 6
Message 3 of 11
Yeah, I just posted the details from them underneath instead to save time.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 4 of 11
set up a Broadband Quality Monitor (BQM) at thinkbroadband.com - this will give you an insight into what is happening with the signal at the Hub, it will take a few hours to get any kind of trend showing.
On here click the Link icon (2 link chain)
 In the URL box paste the link you copied and then click OK
Then
Type 192.168.0.1 (192.168.100.1 in Modem mode) into your browser URL bar and press enter.  When the page appears DO NOT LOG IN but click ‘Check Router Status’. Copy and paste the contents of each tab onto here, a Guru will be along soon to decipher the info.
nanahoho
  • 6
Message 5 of 11
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 6 of 11
@nanahoho wrote:
https://imgur.com/a/tcrTRdr Here's a link to the hub details.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/ffbee8411b1da869a5b378f4cc657cb725...
Do you realize that the link to your Hub details has made your whole gallery public ?
nanahoho
  • 6
Message 7 of 11
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 8 of 11
I can see all the videos and images that you have stored on 'imgur'.
nanahoho
  • 6
Message 9 of 11
Its only 4 images isnt it?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 10 of 11
no.
About 4 hours ago did you post a screen grab from twitter about Dan Rather ?
