catperry
  • 12
Message 1 of 9
Broadband speed dropping
Hello
I'm having issues with my Internet speed dropping. This is causing me major issues when in virtual meetings or in the middle of working online and losing work.
I have checked the cables, carried out several reboots and run a test on the line. Each time I run a test I get a message saying there is an issue and virgin are aware of it, this has been the same for months with not being sorted.
Any help would be very much appreciated
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 9
Re: Broadband speed dropping
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Disable any VPNs that you have running.
Then
Can you please
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again. Use one post for each tab if you wish. Please do not use screen grabs.
catperry
  • 12
Message 3 of 9
catperry
  • 12
Message 4 of 9
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
14990000009.136256 qam12
24910000007.936256 qam11
3507000000936256 qam13
45150000008.637256 qam14
55230000009.136256 qam15
65310000009.937256 qam16
75390000009.636256 qam17
85470000009.337256 qam18
955500000010.336256 qam19
1056300000010.937256 qam20
1157100000010.137256 qam21
125790000009.937256 qam22
1358700000010.637256 qam23
1459500000010.137256 qam24
156350000008.936256 qam25
166430000009.837256 qam26
1765100000010.437256 qam27
186590000009.836256 qam28
196670000009.137256 qam29
206750000009.836256 qam30
216830000001037256 qam31
226910000009.437256 qam32
236990000009.137256 qam33
247070000009.537256 qam34
1Locked36.3101583
2Locked36.3124631
3Locked36.698927
4Locked37.3103450
5Locked36.6123656
6Locked37.3130855
7Locked36.6134713
8Locked37.3148266
9Locked36.6140280
10Locked37.3132329
11Locked37.316774
12Locked37.3179947
13Locked37.6181350
14Locked37.321100
15Locked36.3292741
16Locked37.3257671
17Locked37.3279026
18Locked36.6332888
19Locked37.3401779
20Locked36.6381945
21Locked37.3314415
22Locked37.3318727
23Locked37.3334048
24Locked37.6348220
catperry
  • 12
Message 5 of 9
13940001042.8512064 qam4
24619997643512064 qam3
32580008344.3512064 qam6
43260013243.8512064 qam5
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
catperry
  • 12
Message 6 of 9
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-rtsxl20016u+voc-b.cm
SFID340088
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID340087
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 9
Several of your Downstream Power Levels are too high and several others are knocking on the door.
This will need an engineer to put right.
You can either phone in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
catperry
  • 12
Message 8 of 9
05/11/2020 14:10:50noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 05:37:37noticeSW download Successful - Via NMS
05/11/2020 05:35:15noticeSW Download INIT - Via NMS
04/11/2020 23:20:2criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 10:34:32Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 10:28:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 02:35:0Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/11/2020 03:37:23criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 20:08:12Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/10/2020 11:57:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/10/2020 09:44:28Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/10/2020 07:00:29ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/10/2020 03:32:57ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/10/2020 03:22:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 17:10:31ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 16:53:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 13:16:47Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 03:20:36ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 05:49:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
catperry
  • 12
Message 9 of 9
All the cables and connections look fine.
Thanks for your help
