Eddbur
Message 1 of 7
Broadband speed and dropping out hi
I have very poor upload and download speeds and also dropping out .
I have spent 21/2 hours on the phone waiting and just need some help in contacting virgin.
Tags (1)
  • 24.05K
  • 2.54K
  • 4.36K
Message 2 of 7
Re: Broadband speed and dropping out hi
Is that on wifi connections or ethernet cabled connections - or both?  What package are you on ?  What are you getting?  How are you testing?
Calling in at 08.00 gives the best chance of getting straight through.
You can also text them on 07533 051809 include account name/number and what the issue is – replies may take longer.
A VM person should pick this up here and respond, but it can take several days for them to get here.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 7
What is your contracted speed ?
Which Hub do you have ?
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Eddbur
Message 4 of 7
Hi John
Thank you for the reply . I have connected the laptop to the hub via Ethernet cable and also via Wi-fi . I have connected to various broadband speed sites all giving me similar results.
I am on a 350mb package and virgin states I should get a minimum of 181 download and 35 upload , neither of which I am getting .
I have finally got hold of someone once I went through to the cancellation department and now have an engineer visiting on Thursday
Eddbur
Message 5 of 7
Hi Mike
I am getting 20-25 download and 0.3 upload .
paying for the 350mb package and have finally got through to someone once I said I wanted to cancel due to virgin not fulfilling their part of the contract
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 7
Disable any VPNs that you have running.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 7
Can you please
