Hypnos08
  • 7
Message 1 of 10
Broadband speed Extremely slow
Hello,
From yesterday i have ectremely slow speed downloand/upload. I have FIbre100.
I have check speed by WI-FI and cable. I have check all the cables. I have turn on and off Hub 3 few times and also i have restart it 2 times. Nothing help.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 10
Re: Broadband speed Extremely slow
Please post a 'Live Link' to your BQM on here.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 10
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Hypnos08
  • 7
Message 4 of 10
1483000000-6.238256 qam30
2187000000-2.740256 qam7
3195000000-2.740256 qam8
4203000000-2.940256 qam9
5211000000-340256 qam10
6219000000-3.240256 qam11
7227000000-3.540256 qam12
8235000000-3.740256 qam13
9243000000-4.240256 qam14
10251000000-4.938256 qam15
11259000000-5.438256 qam16
12267000000-4.438256 qam17
13275000000-438256 qam18
14283000000-440256 qam19
15291000000-4.438256 qam20
16299000000-4.238256 qam21
17307000000-4.240256 qam22
18315000000-4.538256 qam23
19323000000-4.538256 qam24
20443000000-6.737256 qam25
21451000000-6.737256 qam26
22459000000-6.537256 qam27
23467000000-6.537256 qam28
24475000000-6.538256 qam29
1Locked38.600
2Locked40.350
3Locked40.350
4Locked40.950
5Locked40.350
6Locked40.960
7Locked40.350
8Locked40.350
9Locked40.370
10Locked38.950
11Locked38.960
12Locked38.950
13Locked38.960
14Locked40.940
15Locked38.940
16Locked38.660
17Locked40.340
18Locked38.940
19Locked38.950
20Locked37.600
21Locked37.650
22Locked37.650
23Locked37.660
24Locked38.650
Hypnos08
  • 7
Message 5 of 10
15369998849.8512064 qam10
23939997947.8512064 qam12
34620002448.3512064 qam11
46030000449.8512064 qam9
3ATDMA0000
4ATDMA0000
Hypnos08
  • 7
Message 6 of 10
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
xv9873254k;fg87dsfd;kfoA,
SFID1058
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID1057
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
Hypnos08
  • 7
Message 7 of 10
27/12/2020 11:54:33noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/12/2020 11:53:45Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/12/2020 02:25:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/12/2020 20:45:54noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/12/2020 14:38:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/12/2020 18:14:14noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/12/2020 18:14:14ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/12/2020 01:13:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2020 06:14:14noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2020 06:14:14ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/12/2020 18:55:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/12/2020 18:14:13noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/12/2020 18:14:13ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/12/2020 05:59:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/12/2020 06:14:14noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/12/2020 06:14:14ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/12/2020 10:13:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/12/2020 18:14:13noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/12/2020 18:14:13ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/12/2020 20:34:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Hypnos08
  • 7
Message 8 of 10
  • 26.49K
  • 2.7K
  • 4.91K
Message 9 of 10
Several of your down channel power levels are below the recommended minimum of -6dBmV. You need to call in (try at 08.00) and see what they say when they look in more detail - it will likely need a tech visit to adjust them.
Hypnos08
  • 7
Message 10 of 10
What could cause this issue?
It was everything ok, I was downloading game on ps4 at speed ~100mbs and at some point download speed drop do 1.5mbs and it stayed that way...
