brennanpeyton
  • 16
Message 1 of 28
Broadband speed Crowthorne
I pay for 300mb and get max 70-80 during the day and 5mb from 4:30 onwards.  This is via speedtest directly to router via ethernet so not a wifi issue.  Why do you sell something you can’t deliver.  Once in a while I understand network congestion but this is every day !! Surely trading standards means you can’t sell what you can’t deliver
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 28
Re: Broadband speed Crowthorne
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 28
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 28
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
brennanpeyton
  • 16
Message 5 of 28
16590000000.538256 qam32
2475000000240256 qam9
3483000000238256 qam10
44910000001.738256 qam11
54990000001.538256 qam12
65070000001.540256 qam13
75150000001.540256 qam14
85230000001.538256 qam15
95310000001.538256 qam16
105390000001.540256 qam17
115470000001.738256 qam18
125550000001.540256 qam19
135630000001.538256 qam20
145710000001.538256 qam21
155790000001.238256 qam22
165870000001.440256 qam23
175950000001.239256 qam24
18603000000138256 qam25
19611000000138256 qam26
206190000000.740256 qam27
216270000000.538256 qam28
226350000000.538256 qam29
236430000000.538256 qam30
246510000000.540256 qam31
1Locked38.6460
2Locked40.9170
3Locked38.9120
4Locked38.9150
5Locked38.9120
6Locked40.3140
7Locked40.3170
8Locked38.9160
9Locked38.9110
10Locked40.3110
11Locked38.6190
12Locked40.3140
13Locked38.9210
14Locked38.9170
15Locked38.9230
16Locked40.3180
17Locked39.8210
18Locked38.9230
19Locked38.9250
20Locked40.3250
21Locked38.6390
22Locked38.9290
23Locked38.9370
24Locked40.3490
pstream bonded channels
16030002949512064 qam1
23939996649512064 qam4
34619998849512064 qam3
45370005149512064 qam2
3ATDMA0010
4ATDMA000
0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
A,.iyewrkldJKDHSUBsgvca69834n
SFID20030
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID20029
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
brennanpeyton
  • 16
Message 6 of 28
10/12/2020 18:18:20noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/12/2020 18:18:5Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/12/2020 21:19:3criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/12/2020 11:14:31noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/12/2020 11:14:31ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/12/2020 06:14:21criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/12/2020 23:14:30noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/12/2020 23:14:30ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/11/2020 20:47:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/11/2020 18:36:58noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/11/2020 18:36:58ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/11/2020 12:12:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/11/2020 22:21:56noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/11/2020 22:21:56ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/11/2020 22:21:54ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2020 10:40:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2020 02:51:56noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2020 02:51:56ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/11/2020 18:34:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/11/2020 14:51:55noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
brennanpeyton
  • 16
Message 7 of 28
Hi its 100MBPS
brennanpeyton
  • 16
Message 8 of 28
ttps://www.thinkbroadband.com/broadband/monitoring/quality/share/c8a987c24561164f1939c4fe728741f84035f623
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 9 of 28
@brennanpeyton wrote:
Hi its 100MBPS
That points to an iffy ethernet cable or a Network Interface Card that is set to the wrong speed or is too old for the speeds you are signed up for.
Can you try a different Cat 5e or better ethernet card and speed test again please.
brennanpeyton
  • 16
Message 10 of 28
We have 5 devices plugged into the router - MESH wifi, Mac Mini x 2 , Apple TV and they are all running slow...  it very occassionally gets up to 240-250MB on speedtest so I don't think its a cable (they are all new ish) or the card in the Mac's
