Jamesstaff1987
Message 1 of 8
Broadband slow
Why isit I've got the fastest broadband you provide but when I stream Netflix amazon prime ect its always buffering I've reset my broadband box evern gone for the boosters what you provide and still rubbish WiFi I've check the speed test and the nothing is what it's ment to be iam being charged for something I've not got not Impressed I will be changing my provider very soon
Tags (1)
  • 26.52K
  • 2.7K
  • 4.92K
Message 2 of 8
Re: Broadband slow
VM (& all other BB providers) provide a service that is guaranteed TO the Hub and what comes out from it on an ethernet cabled device. They all expressly exclude guaranteeing wifi connections - as it is so influenced by the external environment.
Even BT with its glossy Jimmy Nesbitt ad's saying wifi is guaranteed across the home will charge extra fees per month for their kit - also qualify that by saying... if it doesn't get sorted with their "discs"  they will just give you your money back.
VM try and help with swapping the Hub (just in case!) and providing boosters etc., but the reality is, that if the Hub wifi doesnt work well for you then you are far better sourcing your own wireless equipment.
You should try separating the SSID's of the 2.4 and 5 GHz wifi bands and switching off "channel optimisation" - as that often helps Hub3 users get better wifi performance - but its no substitute for better quality kit.
If you cancel the VM contract whilst still in contract you will have to give 30-days notice and also pay early disconnection fees - dependent on how much time is left - I think the maximum is capped at £240 - you would get a cracking Mesh wifi system for that !
Jamesstaff1987
Message 3 of 8
Re: Broadband slow
Well when your paying for the m500 and your ping is 22.66 download is 24.5 upload is 15.97 think something not right there isit
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 8
Re: Broadband slow
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 5 of 8
Re: Broadband slow
A bit more information is required, please post the following ...
Please do this before posting the Hub Data
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 6 of 8
Re: Broadband slow
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Please do not use screen shots.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
Jamesstaff1987
Message 7 of 8
Re: Broadband slow
I don't use it on computer it's just the point where you can't watch a film on Netflix without it buffering or when there's 2 or more devices connect there both lagging I've separated it so phones on 2ghz and firestick on 5 but still no change
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 8 of 8
Re: Broadband slow
Nowt we can do to help on here then.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 10 days average) until one of the VM Forum Staff comes along.
