If you think that you have a BB speed problem, then to check the speeds coming in to your Hub properly, and whether they match what you should be getting, you cannot rely on wifi tests or use old kit, - no BB supplier guarantees wifi - only speeds "TO" the Hub are guaranteed.
So, you need to test speeds directly.... that's on an ethernet cable (Cat5e/6) connected to a GB enabled computer/laptop, with up to date drivers with the Hub switched in modem mode (see VM website for the "how to".
Test at speedtest.net to your nearest VM server - try 2 different browsers.
If they are still low – boot the device into safe+networking mode and try again.
There are many posts on here where unknown software or other "sleeping" connected devices are limiting speeds on tests.
Report back what that gets.
