  • 5
Broadband slow upload speed
Dear Virgin,
I reported slow upload speed around a month ago, 1.5-2 Mbps as opposed to the 20 Mbps.  All connections and router were checked. Download speeds are fine, 200 Mbps. I have discovered that very early in the morning, 8am, upload is ok so believe this may be due to amount of usage in the area or a local hardware fault.  9am onwards it is down to the low level. I would very much appreciate Virgin advice as to whether this can be fixed.
Thanks.
  • 20.96K
  • 1.14K
  • 2.7K
Re: Broadband slow upload speed
Post the network, upstream and downstream logs from the hub
  • 5
8/05/2020 10:00:12noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/05/2020 05:36:23ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/05/2020 00:38:55criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/05/2020 22:06:1ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/05/2020 07:44:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/05/2020 07:05:19ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/05/2020 13:29:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2020 17:00:14ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/05/2020 21:18:55ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/05/2020 16:44:26criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/05/2020 01:27:50Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/05/2020 01:27:45criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/05/2020 01:27:44Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/05/2020 01:27:44criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/05/2020 23:00:1Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/05/2020 22:59:56criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/05/2020 22:59:56Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/05/2020 22:59:55Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/05/2020 19:13:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Upstream
1394002035.1512064 qam4
2603000675.1512064 qam1
3536999875.1512064 qam2
4461999725.1512064 qam3
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
  • 5
Downstream
1187000000-138256 qam7
2195000000-1.238256 qam8
3203000000-1.238256 qam9
4211000000-1.438256 qam10
5219000000-1.238256 qam11
6227000000-1.238256 qam12
7235000000-138256 qam13
8243000000-1.238256 qam14
9251000000-1.238256 qam15
10259000000-1.238256 qam16
11267000000-138256 qam17
12275000000-138256 qam18
13283000000-0.438256 qam19
14291000000-0.438256 qam20
15299000000038256 qam21
163070000000.438256 qam22
173150000000.540256 qam23
183230000000.540256 qam24
193790000000.738256 qam25
203870000000.738256 qam26
213950000001.240256 qam27
224030000001.540256 qam28
234110000001.740256 qam29
244190000001.940256 qam30
1Locked38.91546729310994
2Locked38.91501089210559
3Locked38.9162722729923
4Locked38.61947714815970
5Locked38.91710225416277
6Locked38.61516312616679
7Locked38.91495396316339
8Locked38.91346473520019
9Locked38.91281737719937
10Locked38.61516741720858
11Locked38.91397790619978
12Locked38.91412036517047
13Locked38.91363086820442
14Locked38.6144534519874
15Locked38.6156640507611
16Locked38.9154758487586
17Locked40.3136149298358
18Locked40.3149125308667
19Locked38.93110628513686
20Locked38.6306274819211
21Locked40.32968859410118
22Locked40.3334445698654
23Locked40.3275513288385
24Locked40.9293234797627
  • 20.96K
  • 1.14K
  • 2.7K
The upstream levels are too high and there’s a lot of Post-RS errors on the downstream.
When was the router last rebooted?
Unless there’s an area issue you’ll need a tech visit to resolve
  • 5
Thanks for the quick reply. The router was rebooted around a week ago. I will contact Virgin for a tech visit. Thanks for the help.
