on 25-04-2023 23:02
I had a few text messages regarding work in the area last week, since the work broadband has been very wonky! With regular dropouts and speeds reporting all over the place.
I’ve power cycled the router and internal mesh wi-if a few times, but it’s no better.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/fe934f17d24bf02e843e7e3a4ed10d75690b9788
1 | 203000000 | 12.5 | 36 | QAM 256 | 9 |
2 | 139000000 | 14.4 | 35 | QAM 256 | 1 |
3 | 147000000 | 14 | 35 | QAM 256 | 2 |
4 | 155000000 | 13.3 | 35 | QAM 256 | 3 |
5 | 163000000 | 12.6 | 36 | QAM 256 | 4 |
6 | 171000000 | 12.7 | 36 | QAM 256 | 5 |
7 | 179000000 | 11.6 | 35 | QAM 256 | 6 |
8 | 187000000 | 12.9 | 36 | QAM 256 | 7 |
9 | 195000000 | 13.7 | 36 | QAM 256 | 8 |
10 | 211000000 | 13.5 | 36 | QAM 256 | 10 |
11 | 219000000 | 13.2 | 36 | QAM 256 | 11 |
12 | 227000000 | 12.6 | 36 | QAM 256 | 12 |
13 | 235000000 | 12.9 | 36 | QAM 256 | 13 |
14 | 243000000 | 13 | 36 | QAM 256 | 14 |
15 | 251000000 | 11.6 | 36 | QAM 256 | 15 |
16 | 259000000 | 12.5 | 36 | QAM 256 | 16 |
17 | 267000000 | 12.3 | 36 | QAM 256 | 17 |
18 | 275000000 | 12.3 | 36 | QAM 256 | 18 |
19 | 283000000 | 12.6 | 36 | QAM 256 | 19 |
20 | 291000000 | 10.7 | 36 | QAM 256 | 20 |
21 | 299000000 | 12.5 | 36 | QAM 256 | 21 |
22 | 307000000 | 13 | 36 | QAM 256 | 22 |
23 | 315000000 | 12.3 | 36 | QAM 256 | 23 |
24 | 323000000 | 11.8 | 36 | QAM 256 | 24 |
25 | 331000000 | 12.2 | 36 | QAM 256 | 25 |
26 | 339000000 | 11.3 | 36 | QAM 256 | 26 |
27 | 347000000 | 12.3 | 37 | QAM 256 | 27 |
28 | 355000000 | 12.2 | 36 | QAM 256 | 28 |
29 | 363000000 | 11.1 | 37 | QAM 256 | 29 |
30 | 371000000 | 12 | 37 | QAM 256 | 30 |
31 | 379000000 | 11.2 | 37 | QAM 256 | 31 |
1 | Locked | 36 | 5807521 | 0 |
2 | Locked | 35 | 13887422 | 0 |
3 | Locked | 35 | 11524148 | 0 |
4 | Locked | 35 | 9220182 | 0 |
5 | Locked | 36 | 7812990 | 0 |
6 | Locked | 36 | 7601954 | 0 |
7 | Locked | 35 | 7717914 | 0 |
8 | Locked | 36 | 7455935 | 0 |
9 | Locked | 36 | 6688612 | 0 |
10 | Locked | 36 | 5558732 | 0 |
11 | Locked | 36 | 5191680 | 0 |
12 | Locked | 36 | 4573414 | 0 |
13 | Locked | 36 | 3805718 | 0 |
14 | Locked | 36 | 3665307 | 0 |
15 | Locked | 36 | 3872921 | 0 |
16 | Locked | 36 | 3661277 | 0 |
17 | Locked | 36 | 3239505 | 0 |
18 | Locked | 36 | 3078317 | 0 |
19 | Locked | 36 | 3082608 | 0 |
20 | Locked | 36 | 3084417 | 0 |
21 | Locked | 36 | 2792715 | 0 |
22 | Locked | 36 | 2275438 | 0 |
23 | Locked | 36 | 2098450 | 0 |
24 | Locked | 36 | 2020326 | 0 |
25 | Locked | 36 | 1796350 | 0 |
26 | Locked | 36 | 1562638 | 0 |
27 | Locked | 37 | 1395334 | 0 |
28 | Locked | 36 | 1344693 | 0 |
29 | Locked | 37 | 1361570 | 0 |
30 | Locked | 37 | 1276072 | 0 |
31 | Locked | 37 | 1183496 | 0 |
0 | 49600000 | 34.8 | 5120 | QAM 64 | 9 |
1 | 43100000 | 37.3 | 5120 | QAM 64 | 10 |
2 | 36600000 | 34.3 | 5120 | QAM 64 | 11 |
3 | 30100000 | 39.3 | 5120 | QAM 64 | 12 |
4 | 23600000 | 36.3 | 5120 | QAM 64 | 13 |
0 | ATDMA | 0 | 0 | 0 | 0 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
25-04-2023 21:51:23 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
25-04-2023 21:51:23 | notice | US profile assignment change. US Chan ID: 14; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
25-04-2023 21:51:19 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
25-04-2023 21:51:13 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
25-04-2023 21:51:13 | warning | Dynamic Range Window violation |
25-04-2023 21:51:13 | warning | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
25-04-2023 21:51:08 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
25-04-2023 21:50:55 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
25-04-2023 21:50:53 | notice | Honoring MDD; IP provisioning mode = IPv4 |
25-04-2023 21:50:43 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
25-04-2023 21:50:32 | critical | Cable Modem Reboot due to RG crash |
25-04-2023 10:53:00 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
25-04-2023 10:52:48 | critical | Cable Modem Reboot due to RG crash |
25-04-2023 09:47:09 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
25-04-2023 09:46:57 | critical | Cable Modem Reboot due to RG crash |
25-04-2023 02:06:01 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
25-04-2023 02:05:49 | critical | Cable Modem Reboot due to RG crash |
24-04-2023 23:42:19 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
24-04-2023 23:42:08 | critical | Cable Modem Reboot due to RG crash |
24-04-2023 20:08:59 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
24-04-2023 20:08:47 | critical | Cable Modem Reboot due to RG crash |
23-04-2023 19:58:42 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
23-04-2023 19:58:31 | critical | Cable Modem Reboot due to power button reset |
23-04-2023 14:12:36 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
23-04-2023 14:12:24 | critical | Cable Modem Reboot due to RG crash |
23-04-2023 11:59:10 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 25-04-2023 23:11
Downstream power levels too high and upstream on the low side. This indicates you have a too good a signal! You need moving to another tap on the street cabinet. You need a technician’s visit for this.
Check with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level. You could also try the web page status, but this is not recommended as it only covers issues that affect a very large number of customers.
VM will not dispatch any technicians while an area fault exists.
If no area faults found:
The primary place to report faults or for service requests is Customer Services on 0345 454 1111/150 if you have a VM landline or wait two or three days for a VM staff member to get to your post.
on 25-04-2023 23:15
Cheers for the info and diag.
I generally post here and wait for staff to pick it up, can’t stand phoning in, just winds me up 9/10 times.
Kids have figured out hot spot usage so not urgent as such. Just a pain all round!!
26-04-2023 13:15 - edited 26-04-2023 13:15
Thats some latency and jitter your having I doubt power levels are to blame
on 28-04-2023 15:53
Hey @WookieeM,
Welcome back to the Community Forums and thanks for the post.
From looking into our systems and what you have posted, I would like to invite you into a quick private message which I will be sending out to you now.
If you have not used our private message feature before you can access it via the the envelope at the top of your screen.
Thanks. Joe
on 28-04-2023 17:00
Engineer booked for Monday, cheers.
on 28-04-2023 17:00
Hey @WookieeM,
Glad we were able to sort that In a quick private chat, if you do have any future queries please do reach out.
Cheers. Joe
30-04-2023 08:17 - edited 30-04-2023 08:17
Issue Resolved - Please cancel tech visit
Sharing as it may help others when they do stupid network cabling too!
I've moved the appointment to Thur 25th May, but please cancel it, I did not find any options to cancel the visit in the app.
The issue must have been some creative wiring between the router, a switch and the mesh wi-fi gateway. I re-wired them as part of my troubleshooting and pretty sure the router and switch were looped (connected with two cables).
But the speeds are now fine and the broadband monitor is back to normal. My kids are been educated on networks too.
Kevin.
(Copied on PM to @Joseph_B too)
