joess83
  • 6
Message 1 of 10
Broadband regularly drops out
We seem to have problems with the Internet connection completely dropping out for a short period of time before reconnecting. This is happening even when our computers are hardwired, so it doesn't feel like a wifi problem. Usually happens when we are delivering a webinar or something important! Meant to be a 100mb connection. Feels like it may be a problem between the home and the cabinet (which incidentally is often left unlocked and with the doors open, so perhaps someone is fiddling with it who isn't meant to).
07/06/2020 12:27:28noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/06/2020 12:27:21Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/06/2020 10:51:39noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/06/2020 03:18:50ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/06/2020 12:29:20ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/06/2020 07:51:6criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/06/2020 21:39:54ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/06/2020 03:45:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/06/2020 08:57:24ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/05/2020 12:50:21ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/05/2020 18:15:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
joess83
  • 6
Message 2 of 10
Re: Broadband regularly drops out
Output of broadband monitorOutput of broadband monitor
-tony-
  • 16.54K
  • 1.31K
  • 3.9K
Message 3 of 10
log into hub3 - 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and post the downstream and upstream figures - to see those press on the grey buttons/boxes labeled - upstream - downstream
if its an earlier hub button is top right
____________________
Tony
joess83
  • 6
Message 4 of 10
11870000005.137256 qam7
2195000000537256 qam8
3203000000537256 qam9
42110000004.937256 qam10
52190000004.937256 qam11
62270000004.837256 qam12
72350000004.637256 qam13
82430000004.537256 qam14
92510000004.437256 qam15
102590000004.437256 qam16
112670000004.437256 qam17
122750000004.537256 qam18
132830000004.638256 qam19
142910000004.637256 qam20
15299000000537256 qam21
16307000000538256 qam22
17315000000537256 qam23
183230000005.338256 qam24
193790000005.438256 qam25
20387000000538256 qam26
21395000000538256 qam27
224030000004.938256 qam28
234110000004.938256 qam29
244190000004.838256 qam30
1Locked37.350617
2Locked37.638712
3Locked37.632515
4Locked37.33420
5Locked37.62711
6Locked37.62900
7Locked37.63800
8Locked37.33410
9Locked37.67620
10Locked37.34230
11Locked37.32230
12Locked37.63910
13Locked38.62840
14Locked37.62700
15Locked37.62010
16Locked38.62370
17Locked37.33430
18Locked38.62130
19Locked38.62680
20Locked38.620614
21Locked38.62600
22Locked38.62800
23Locked38.61940
24Locked38.62260
joess83
  • 6
Message 5 of 10
1603000004.35512064 qam1
2537000004.3512064 qam2
3394000004.2512064 qam4
4462000004.25512064 qam3
3ATDMA0000
4ATDMA0000
-tony-
  • 16.54K
  • 1.31K
  • 3.9K
Message 6 of 10
theres nothing there to suggest problems so do wired and wifi connections both fail - if you dont have any wired devices what do the hub lights do when the connection drops
Tony
joess83
  • 6
Message 7 of 10
Not sure about the hub lights as I don't have the hub in a nearby room. Sorry, I know that's not helpful!
-tony-
  • 16.54K
  • 1.31K
  • 3.9K
Message 8 of 10
so again do wired connections drop or is it just wifi
Tony
joess83
  • 6
Message 9 of 10
Wired connections drop. Is the same for wireless and wired.
  • 22.48K
  • 2.4K
  • 4.02K
Message 10 of 10
If wired is dropping it will be evident on the BQM as a vertical red bar at the same time as its reported in the logs. Can you post that up?
