Bug53y79
Message 1 of 5
Broadband problems
I have a virgin hub 3 and on theM350 service. However my speeds are not going above 15mb and the Hub3 is showing a solid Amber light. How do I fix this as I need internet for home and business.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 5
Re: Broadband problems
Go through the >> VM Troubleshooting <<
Bug53y79
Message 3 of 5
Done and done. Before you messaged. Being from an electronic and microcumputing background I am already aware of this. Looking for other solutions as the vm trouble shooting doesn't mention an Amber light.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 5
It does mention a yellow light though !
What speed do you get using a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
It can be difficult diagnosing problems without some basic information.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Bug53y79
Message 5 of 5
Thank you for your help. Contacted virgin direct and it seems they had a glitch at their end which we hadn't been informed of and its now running at full tilt again. The information you provided was a big help though. thankyou
