Billing
Broadband m200 but speed is low
Hello! I ordered 200 megabytes per second internet.And in fact it turned out to be much slower.Today at night the decline in internet was up to 30 megabits per second.
I wanted to play in the cloud, for example at stadia or Nvidia game, but this is not impossible.
Tags (1)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Broadband m200 but speed is low
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
Billing
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
@MikeRobbo wrote:
... snip ...
Billing
Hello, I am using a wireless device to connect WiFi.Today it got a little better because it is 144 MB per second,but this is far below what I can get.I think the connection is somewhat unstable because yesterday at 21:00 the transfer rate was very low.I recorded 22 mb per second of download and 8 mb/s upload 8mb/s
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
VM will not accept Wi-Fi speeds as evidence of low speed.
You really do need to test at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected
